Issues while migrating from Grafana v8.3.6 to latest(v9.1.6), especially from Elastic Search to OpenSearch
    We are currently using v8.3.6 in Ubuntu 20.04.4 LTS (Linux environment)
    We are migrating to the latest grafana version v9.1.2.
    By following the same documentation where we take up the backup, copy-paste the current grafana.db file to the path /var/lib/grafana, update ini file.
  • What happened?
    We Can see the data on the Dashboard but when I go and try to edit the same, we get this issue
An unexpected error happened for EXISTING Dashboards.
TypeError: Cannot read properties of undefined (reading ‘label’)
at Fn (https://grafana-mumbai.coinswitch.co/public/plugins/grafana-opensearch-datasource/module.js:2:151059) at div at div at div at du …
    I was expecting this migration to run smoothly.
    Panel JSON
  "id": 6,
  "gridPos": {
    "h": 9,
    "w": 12,
    "x": 0,
    "y": 8
  "type": "graph",
  "title": "Low logs on 1box",
  "alert": {
    "alertRuleTags": {},
    "conditions": [
        "evaluator": {
          "params": [
            5
          "type": "lt"
        "operator": {
          "type": "and"
        "query": {
          "params": [
            "A",
            "2m",
            "now"
        "reducer": {
          "params": [],
          "type": "sum"
        "type": "query"
    "executionErrorState": "alerting",
    "for": "0m",
    "frequency": "60s",
    "handler": 1,
    "name": "Low logs on 1box alert",
    "noDataState": "no_data",
    "notifications": [
        "id": 4
  "datasource": {
    "type": "elasticsearch",
    "uid": "000000030"
  "thresholds": [
      "value": 5,
      "op": "lt",
      "visible": true,
      "fill": true,
      "line": true,
      "colorMode": "critical"
  "pluginVersion": "9.1.6",
  "description": "Check if 1box traffic is disabled or not. It could be because of low peak hours as well",
  "links": [],
  "legend": {
    "avg": false,
    "current": false,
    "max": false,
    "min": false,
    "show": true,
    "total": false,
    "values": false
  "aliasColors": {},
  "bars": false,
  "dashLength": 10,
  "dashes": false,
  "fill": 1,
  "fillGradient": 0,
  "hiddenSeries": false,
  "lines": true,
  "linewidth": 1,
  "nullPointMode": "null",
  "options": {
    "alertThreshold": true
  "percentage": false,
  "pointradius": 5,
  "points": false,
  "renderer": "flot",
  "seriesOverrides": [],
  "spaceLength": 10,
  "stack": false,
  "steppedLine": false,
  "targets": [
      "bucketAggs": [
          "field": "@timestamp",
          "id": "2",
          "settings": {
            "interval": "auto",
            "min_doc_count": 0,
            "trimEdges": 0
          "type": "date_histogram"
      "datasource": {
        "uid": "000000030"
      "metrics": [
          "field": "select field",
          "id": "1",
          "type": "count"
      "query": "\"1box\"",
      "refId": "A",
      "timeField": "@timestamp"
  "timeRegions": [],
  "tooltip": {
    "shared": true,
    "sort": 0,
    "value_type": "individual"
  "transparent": true,
  "xaxis": {
    "mode": "time",
    "show": true,
    "values": [],
    "name": null,
    "buckets": null
  "yaxes": [
      "format": "short",
      "logBase": 1,
      "show": true
      "format": "short",
      "logBase": 1,
      "show": true
  "yaxis": {
    "align": false
  "timeFrom": null,
  "timeShift": null
Details
TypeError: Cannot read properties of undefined (reading 'label')
    at div
    at div
    at div
    No
Please note
  1. When I create a new dashboard or a new panel in the existing dashboard, it is working very fine. So, I wanted help in how to migrate the json_data(that has elastic search data) that is stored in dashboard table that can smoothly work with Opensearch.
  2. When I tried to migrate from v8.3.6 to v9.1.6(latest), alerts are also not compatible. Can you throw some light here please?
Much appreciated!
