Grafana 11.5.2 - What are you trying to achieve?
Make imported graphs/dashboard work. - How are you trying to achieve it?
Reconfiguring the dashboards to connect to opensearch/elasticsearch - What happened?
Dashboards have no entries/ no data. or pulling incorrect data. - What did you expect to happen?
To pull data from my elasticsearch - Can you copy/paste the configuration(s) that you are having problems with?
I have a .json file. - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no errors - Did you follow any online instructions? If so, what is the URL?
No URL
