Why documents imported from ES are not complete?
    Grafana v7.5.17 (84411794f3)
    Windows 11
    I would like to import data from ES index to Grafana Dashboard
    I’ve configured a ES index as data source, and created a table in Grafana Dashboard.
  • What happened?
    However, I found the data is not complete. For example, the documents in ES index started from Nov. 2022. But the data in Grafana Dashboard table are only back to Aug. 2023.
    I expect all documents in ES index should be presented in Grafana Dashboard table.
    No
    Panels and visualizations | Grafana documentation
Can you please share the lucene query you are using
Actually I don’t use any query. Simply import all data from index.
