Grafana sharing panel info
Hi All:
I am trying to create a panel that will provide an overall status of 3 existing panels on the same dashboard. 3 panels track whether or not specific services are running (status:Up or Down)… This part is Ok. I need another panel that will be an aggregate for the other 3 panels.
I’m sure something as simple as boolean would not work… “if ‘panel 1’ is down then show ‘this message’ on Overall panel”, but what would work. The closest that I’ve come is the “Use results from panel” option, but I have 3 existing panels, not just one.
I’m running Grafana v9.1.6 and Zabbix v6.2. I have been looking for a way to do this for about a month with no luck.
Does anyone know if this is possible?
Thanks for your help.
Mike
