Grafana integrate with Zabbix
zabbix
#1
Hi all,
I have a question here, is it possible for me to have a single dashboard that indicate 20 servers status?
The situation is:
My Zabbix Server had monitored around 20 servers and I want to see the server status whether it have problem or not (Green / Red) appears in a single dashboard - Grafana.
Thanks.
#2
You can make 20 single-stat panels for each server in one dashboard.
Click “add new panel” -> “single stat panel” 20 times :slight_smile:
#3
Thanks Jony! Sorry for the late reply. :sweat_smile:
