Hi, We are using Zabbix for monitoring different Servers on different networks and were looking at Grafana to consolidate all the zabbix data on a single dashboard. Is it possible & how?
Not sure what you mean, do you have a single zabbix server or multiple? You can use multiple zabbix data sources or one to build dashboards that shows data from any number of servers.
Thanks Torkel. We have multiple Zabbix servers & are looking at consolidating the information across them.
You can create Zabbix data source for each of your zabbix instances and combine it into one dashboard or even on one panel (by using mixed data sources).
Thanks Alexander. This helps.
