Grafana Latency SLO Reporting >100%
    AWS managed Grafana v.9.4.7
    Implementing SLOs for various services within the company
    AWS managed Grafana, Mimir, SLOth, AlertManager…
  • What happened?
    Grafana SLO dashboard reported a value greater than 100%
    We expect an SLI to max out at 100%, not higher as a service cannot outperform 100%.
    N/A
    N/A
In essence, my company has seen two separate SLIs report a number greater than 100% which isn’t mathematically possible. We are unsure why, but wonder if it can be attributed to a delay in receiving metrics for any given reason, so the preceding buckets are missing the metrics. These metrics then get picked up in the next. Has anyone experienced this?
image (3)
Interesting that your spike above 100% is the mirror of your drop just before… What is the query you use ?
Edit: I believe it would be related to Prometheus, not Grafana.
We’ve noticed instances where there isn’t a mirror of the spike. We also think it’s a Prometheus issue but spoke with Grafana about it and they are investigating. They believe it’s either a PromQL or dashboarding issue. Still waiting for them to give a formal explanation
We are also seeing this issue; we have SLOs that are reporting greater than 100% SLI performance, which should be impossible. I tried setting the display to show only values between 0 (min) and 1 (max) but that had no effect.
I would love to hear the outcome of this as we are trying to push SLO adoption but issues like this make users dismissive of the entire solution.
I see that you are using Sloth so the problem can come from:
  • Grafana dashboarding not being accurate (then why only for that ?)
  • The Sloth project having a bug (it’s pretty stable, so I doubt it)
  • Prometheus bug
  • Misconfiguration of Sloth (rule that can do more than 100% in some edge cases ?)
Can you find one of this occurence, edit the panel, toggle the table view, and see if you have some values greater than 1.
  • If that’s the case then it’s not a UI problem, it’s a data generation / query engine problem
  • If that’s NOT the case, then it’s a UI problem. It receives 100% and displays more than 100%
