We have an issue in grafana dashboards, The Latency & Quantile widgets are not working i.e, when we change time to Last 7 days . It is getting Gateway Timeout Error. Is there any solution for this issue?
Grafana version - Grafana v7.5.17 , Ubuntu, Datasource - Prometheus -
- The Latency & Quantile widgets are not working i.e, when we change time to Last 7 days . It is getting Gateway Timeout Error
- How are you trying to achieve it?
- What happened?
we have created Latency graphs it is working for last days 2 days, when we changed time frame to last 7 days it showed error. - What did you expect to happen?
- After changing time frame, the graphs should work
- Did you follow any online instructions? If so, what is the URL?
