The json code of the dashboard which is making slow to grafana is below:
"__inputs": [
“name”: “DS_TELEGRAF”,
“label”: “Telegraf”,
“description”: “”,
“type”: “datasource”,
“pluginId”: “influxdb”,
“pluginName”: “InfluxDB”
"__requires": [
“type”: “grafana”,
“id”: “grafana”,
“name”: “Grafana”,
“version”: “4.2.0-pre1”
“type”: “panel”,
“id”: “graph”,
“name”: “Graph”,
“version”: “”
“id”: “influxdb”,
“name”: “InfluxDB”,
“version”: “1.0.0”
“type”: “panel”,
“id”: “jdbranham-diagram-panel”,
“name”: “Diagram”,
“version”: “1.4.0”
“type”: “panel”,
“id”: “singlestat”,
“name”: “Singlestat”,
“version”: “”
“annotations”: {
“list”: []
“editable”: true,
“gnetId”: null,
“graphTooltip”: 0,
“hideControls”: false,
“id”: null,
“links”: [],
“rows”: [
“collapse”: false,
“height”: 227,
“panels”: [
“colors”: [
“rgba(50, 172, 45, 0.97)”,
“rgba(237, 129, 40, 0.89)”,
“rgba(245, 54, 54, 0.9)”
“content”: “graph TB;\n A[xxxxx]— |Server Diagram| B{Hosts};\n click B “http://www.github.com” “This is a tooltip for a link”\n B-.->C[Ip: 192.168.0.];\n C–>H[Host: zenoss51];\n C–>E[49 fa:fa-spinner];\n B-.->D[Ip: 192.168.1.];\n D–>F[Host: xxxxrhel6];\n D–>G[35 fa:fa-spinner];\n\n style A fill:#9954BB,stroke:#333,stroke-width:2px;\n style B fill:#E671B8,stroke:#333,stroke-width:2px;\n style C fill:#2AB2E4,stroke:#333,stroke-width:2px;\n style D fill:#01A64F,stroke:#333,stroke-width:2px;\n style E fill:#F79520,stroke:#333,stroke-width:2px;\n style F fill:#ff4c4c,stroke:#333,stroke-width:2px;\n style G fill:#b3b3b3,stroke:#333,stroke-width:2px;\n style H fill:#FFFF99,stroke:#333,stroke-width:2px;\n “,
“format”: “none”,
“graphId”: “diagram_1”,
“height”: “464”,
“id”: 1,
“init”: {
“arrowMarkerAbsolute”: true,
“cloneCssStyles”: false,
“flowchart”: {
“htmlLabels”: true,
“useMaxWidth”: true
“gantt”: {
“barGap”: 4,
“barHeight”: 20,
“fontFamily”: ““Open-Sans”, “sans-serif””,
“fontSize”: 11,
“gridLineStartPadding”: 35,
“leftPadding”: 75,
“numberSectionStyles”: 3,
“titleTopMargin”: 25,
“topPadding”: 50
“logLevel”: 3,
“sequenceDiagram”: {
“actorMargin”: 50,
“bottomMarginAdj”: 1,
“boxMargin”: 10,
“boxTextMargin”: 5,
“diagramMarginX”: 50,
“diagramMarginY”: 10,
“height”: 65,
“messageMargin”: 35,
“mirrorActors”: true,
“noteMargin”: 10,
“useMaxWidth”: true,
“width”: 150
“startOnLoad”: false
“legend”: {
“avg”: true,
“current”: true,
“gradient”: {
“enabled”: true,
“show”: true
“max”: true,
“min”: true,
“show”: false,
“total”: true
“links”: [],
“mappingType”: 1,
“maxDataPoints”: 100,
“maxWidth”: false,
“nullPointMode”: “connected”,
“seriesOverrides”: [],
“span”: 6,
“targets”: [
“refId”: “A”
“thresholds”: “0,10”,
“title”: “Service Topology”,
“type”: “jdbranham-diagram-panel”,
“valueMaps”: [
“op”: “=”,
“text”: “N/A”,
“value”: “null”
“valueName”: “avg”,
“valueOptions”: [
“avg”,
“min”,
“max”,
“total”,
“current”
“cacheTimeout”: null,
“colorBackground”: false,
“colorValue”: true,
“colors”: [
“datasource”: “${DS_TELEGRAF}”,
“format”: “percent”,
“gauge”: {
“maxValue”: 100,
“minValue”: 0,
“show”: false,
“thresholdLabels”: false,
“thresholdMarkers”: true
“id”: 2,
“interval”: null,
“links”: [],
“mappingType”: 1,
“mappingTypes”: [
“name”: “value to text”,
“value”: 1
“name”: “range to text”,
“value”: 2
“nullText”: null,
“postfix”: “”,
“postfixFontSize”: “50%”,
“prefix”: “”,
“prefixFontSize”: “50%”,
“rangeMaps”: [
“from”: “null”,
“text”: “N/A”,
“to”: “null”
“span”: 2,
“sparkline”: {
“fillColor”: “rgba(31, 118, 189, 0.18)”,
“full”: true,
“lineColor”: “rgb(31, 120, 193)”,
“show”: true
“targets”: [
“dsType”: “influxdb”,
“groupBy”: [],
“measurement”: “cpu”,
“policy”: “default”,
“refId”: “A”,
“resultFormat”: “time_series”,
“select”: [
“params”: [
“usage_system”
“type”: “field”
“tags”: []
“thresholds”: “50,100”,
“title”: “Cpu Usage”,
“type”: “singlestat”,
“valueFontSize”: “80%”,
“valueMaps”: [
“op”: “=”,
“text”: “N/A”,
“value”: “null”
“valueName”: “avg”
“colorValue”: false,
“colors”: [
“format”: “decbytes”,
“gauge”: {
“maxValue”: 100,
“minValue”: 0,
“show”: false,
“id”: 3,
“interval”: null,
“links”: [],
“mappingType”: 1,
“mappingTypes”: [
“value”: 1
“value”: 2
“nullText”: null,
“postfix”: “”,
“prefix”: “”,
“rangeMaps”: [
“from”: “null”,
“text”: “N/A”,
“to”: “null”
“span”: 2,
“sparkline”: {
“full”: true,
“show”: true
“targets”: [
“groupBy”: [],
“measurement”: “mem”,
“refId”: “A”,
“select”: [
“params”: [
“available”
“type”: “field”
“tags”: []
“thresholds”: “”,
“title”: “Memory Available”,
“valueMaps”: [
“op”: “=”,
“text”: “N/A”,
“value”: “null”
“valueName”: “avg”
“colors”: [
“rgba(245, 54, 54, 0.9)”,
“gauge”: {
“maxValue”: 100,
“minValue”: 0,
“show”: false,
“id”: 4,
“interval”: null,
“links”: [],
“mappingType”: 1,
“mappingTypes”: [
“value”: 1
“value”: 2
“nullText”: null,
“postfix”: “”,
“prefix”: “”,
“rangeMaps”: [
“from”: “null”,
“text”: “N/A”,
“to”: “null”
“span”: 2,
“sparkline”: {
“full”: false,
“show”: false
“targets”: [
“groupBy”: [],
“query”: “SELECT “used” FROM “disk” WHERE $timeFilter”,
“rawQuery”: true,
“refId”: “A”,
“select”: [
“params”: [
“value”
“type”: “field”
“tags”: []
“thresholds”: “”,
“title”: “Disk Usage”,
“valueMaps”: [
“op”: “=”,
“text”: “N/A”,
“value”: “null”
“valueName”: “avg”
“aliasColors”: {},
“bars”: false,
“fill”: 1,
“id”: 5,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: false,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 1,
“links”: [],
“nullPointMode”: “null”,
“percentage”: true,
“pointradius”: 2,
“points”: true,
“renderer”: “flot”,
“span”: 3,
“stack”: true,
“steppedLine”: false,
“targets”: [
“groupBy”: [
“params”: [
”$__interval”
“type”: “time”
“params”: [
“null”
“type”: “fill”
“query”: “SELECT top(“usage_system”, 5) FROM “cpu” WHERE $timeFilter GROUP BY “host””,
“rawQuery”: true,
“refId”: “A”,
“select”: [
“params”: [
“value”
“type”: “field”
“params”: [],
“type”: “mean”
“tags”: []
“thresholds”: [],
“timeFrom”: null,
“timeShift”: null,
“title”: “Top 5 CPU used Hosts”,
“tooltip”: {
“shared”: true,
“sort”: 0,
“value_type”: “individual”
“type”: “graph”,
“xaxis”: {
“mode”: “time”,
“name”: null,
“show”: true,
“values”: []
“yaxes”: [
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“aliasColors”: {},
“bars”: false,
“fill”: 1,
“id”: 6,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: false,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 1,
“links”: [],
“percentage”: false,
“pointradius”: 5,
“points”: false,
“renderer”: “flot”,
“span”: 3,
“stack”: true,
“targets”: [
“groupBy”: [
“params”: [
"$__interval"
“type”: “time”
“params”: [
“null”
“type”: “fill”
“query”: “SELECT “used” FROM “mem” WHERE $timeFilter GROUP BY “host””,
“rawQuery”: true,
“refId”: “A”,
“select”: [
“params”: [
“value”
“type”: “field”
“params”: [],
“type”: “mean”
“tags”: []
“thresholds”: [],
“timeFrom”: null,
“timeShift”: null,
“title”: “Top Memory Utilized Hosts”,
“tooltip”: {
“shared”: true,
“sort”: 0,
“type”: “graph”,
“xaxis”: {
“mode”: “time”,
“name”: null,
“show”: true,
“values”: []
“yaxes”: [
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“colorValue”: true,
“colors”: [
“gauge”: {
“maxValue”: 100,
“minValue”: 0,
“show”: false,
“id”: 7,
“interval”: null,
“links”: [],
“mappingType”: 1,
“mappingTypes”: [
“value”: 1
“value”: 2
“nullText”: null,
“postfix”: “”,
“prefix”: “”,
“rangeMaps”: [
“from”: “null”,
“text”: “N/A”,
“to”: “null”
“span”: 2,
“sparkline”: {
“full”: false,
“show”: false
“targets”: [
“groupBy”: [],
“measurement”: “win_cpu”,
“query”: “SELECT “n_cpus” FROM “system” WHERE $timeFilter”,
“rawQuery”: false,
“refId”: “A”,
“select”: [
“params”: [
“Percent_User_Time”
“type”: “field”
“tags”: []
“title”: “Windows Cpu Usage Time”,
“valueMaps”: [
“op”: “=”,
“text”: “N/A”,
“value”: “null”
“valueName”: “avg”
“colors”: [
“gauge”: {
“maxValue”: 100,
“minValue”: 0,
“show”: false,
“id”: 8,
“interval”: null,
“links”: [],
“mappingType”: 1,
“mappingTypes”: [
“value”: 1
“value”: 2
“nullText”: null,
“postfix”: “”,
“prefix”: “”,
“rangeMaps”: [
“from”: “null”,
“text”: “N/A”,
“to”: “null”
“span”: 2,
“sparkline”: {
“full”: false,
“show”: false
“targets”: [
“groupBy”: [],
“measurement”: “win_mem”,
“refId”: “A”,
“select”: [
“params”: [
“Available_Bytes”
“type”: “field”
“tags”: []
“thresholds”: “”,
“title”: “Windows Available Memory”,
“valueMaps”: [
“op”: “=”,
“text”: “N/A”,
“value”: “null”
“valueName”: “avg”
“aliasColors”: {},
“bars”: false,
“fill”: 1,
“id”: 10,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: false,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 1,
“links”: [],
“pointradius”: 2,
“points”: false,
“renderer”: “flot”,
“span”: 4,
“stack”: true,
“targets”: [
“groupBy”: [
“params”: [
“host”
“type”: “tag”
“measurement”: “net”,
“refId”: “A”,
“select”: [
“params”: [
“ip_defaultttl”
“type”: “field”
“tags”: []
“thresholds”: [],
“timeFrom”: null,
“timeShift”: null,
“title”: “Default Network Ip”,
“tooltip”: {
“shared”: true,
“sort”: 0,
“type”: “graph”,
“xaxis”: {
“mode”: “time”,
“name”: null,
“show”: true,
“values”: []
“yaxes”: [
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“aliasColors”: {},
“bars”: false,
“fill”: 2,
“id”: 9,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: false,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 1,
“links”: [],
“pointradius”: 2,
“points”: true,
“renderer”: “flot”,
“span”: 4,
“stack”: true,
“steppedLine”: true,
“targets”: [
“groupBy”: [
“params”: [
“host”
“type”: “tag”
“measurement”: “disk”,
“refId”: “A”,
“select”: [
“params”: [
“used”
“type”: “field”
“params”: [
“5”
“type”: “top”
“tags”: []
“thresholds”: [],
“timeFrom”: null,
“timeShift”: null,
“title”: “Top 5 Disk Utilized Hosts”,
“tooltip”: {
“shared”: false,
“sort”: 0,
“type”: “graph”,
“xaxis”: {
“mode”: “time”,
“name”: null,
“show”: true,
“values”: []
“yaxes”: [
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“repeat”: null,
“repeatIteration”: null,
“repeatRowId”: null,
“showTitle”: false,
“title”: “Dashboard Row”,
“titleSize”: “h6”
“schemaVersion”: 14,
“style”: “dark”,
“tags”: [],
“templating”: {
“list”: []
“time”: {
“from”: “now-30d”,
“to”: “now”
“timepicker”: {
“refresh_intervals”: [
“5s”,
“10s”,
“30s”,
“1m”,
“5m”,
“15m”,
“30m”,
“1h”,
“2h”,
“1d”
“time_options”: [
“5m”,
“15m”,
“1h”,
“6h”,
“12h”,
“24h”,
“2d”,
“7d”,
“30d”
“timezone”: “browser”,
“title”: “Service Overview”,
“version”: 53
