Nobl9 to Grafana dashboard - Error Budget rate calculation
So we are migrating from nobl9 to grafana.
As nobl9 is completely based on SLO’s. I started with few panels but the problem is the error budget remaining, and burn rate.
There is no explicit information on how it is all calculated.
My data is all from dynatrace - which is all 5xx and 4xx errors it will be time series data for that kind of that how the calculation will be.
That sounds like a question for your old monitoring tool support, not for Grafana.
You can check the Grafana doc if you want to know more about how SLO works in Grafana Cloud:
Hi @jangaraj , thanks for replying
In Grafana Cloud, SLO based visualization is available, we are with an Enterprise license but we do not have SLO in this.
So just want to try recreating the error budget remaining and burn rate and reliability. Is there any way we can do.
Correct, that’s Grafana Cloud feature, which is not available in the on-prem deployments.
But nobody is stopping you to write own SLI/SLO/SLA queries for your needs.
