I’m noticing if you have multiple metrics on a panel and go to inspect > Data and toggle the ‘Join by Time’ prior to hitting the ‘Download CSV’ button, if any of the metrics have null data for a specific time, then all the other metrics will also not have that time when downloading. It essentially finds only times that all metrics have a value for… Is this intended? Previously, before Grafana 7, if you downloaded data and something was null it would just be a null value in the resulting CSV.
Related topics
| Topic | Replies | Views | Activity | |
| How to skip/filter out rows with missing data? | 26 | 5908 | December 11, 2025 | |
| Grafana v9 is tryning to merge times values axes when using mulitple metrics and create 0 value if need be | 1 | 353 | April 26, 2023 | |
| How do I join the dots here? | 4 | 1547 | November 27, 2021 | |
| TimeSeries is plotting 0 instead of 'Null' at times where there is no data | 6 | 944 | March 7, 2024 | |
| No graph when 'null value' is not set to connected , while there are no holes in database | 1 | 867 | March 27, 2018 |
