How to avoid Grafana handling NULL values from Google BigQuery as 0
I have the doitintl BigQuery plugin (v2.0.2) installed for my Grafana instance (v8.2.7).
My SQL query is based on multiple tables and is joined with a full outer join on the timestamp column. Therefore, I have some null values returned for some of the other columns and they are shown as such in the GCP BigQuery Console.
However, when I run the query in my time series panel, those null values are treated as zeros, leading to an undesired graph.
Is there a way to avoid that behaviour in Grafana?
hmmm, not sure if we’ve fixed that bug, but Grafana forked that plugin and has taken over development:
it’s still in beta and not published, but you can build it from source…
Seems like it is fixed in the forked version (tested v0.1.10). Thanks!
