Grafana with Athena Query converts my NULLs to zeros
I use Grafana Cloud with Athena plugin - and my query somehow converts NULLs to zeros (0). When I run the same query in Athena I get the NULL values as expected, but in Grafana they are COALESCEd for me.
Plugins: Amazon Athena v.1.0.1
Disconnect dots in a time series → retrieve NULL values from athena.
My query selects a “value” field which contains NULL
  • What happened?
The data retrieved converts my NULL to zero (0)
That the NULL will remain NULL
From Athena:
SELECT COUNT(*) FROM wall.wall_data WHERE value IS NULL # I get the records I expect
Highlights from the query inspector JSON:
  "request": {
    "url": "api/ds/query",
    "method": "POST",
    "data": {
      "queries": [
          "column": "value",
          "connectionArgs": {
            "catalog": "__default",
            "database": "__default",
            "region": "__default"
          "datasource": {
            "type": "grafana-athena-datasource"
          "format": 0,
          "hide": false,
          "rawSQL": "SELECT date_parse(\"timestamp-utc\", '%Y-%m-%d %H:%i:%s UTC') AS dt,\r\n\"home-name\", \"wall-name\", \"sensor-name\", \r\nvalue \r\nFROM wall_data \r\nWHERE \"measurement-type\"='temp_c'\r\nORDER BY 1 ASC;",
          "refId": "Temperature",
          "table": "wall_data",
          "datasourceId": 20,
          "intervalMs": 30000,
          "maxDataPoints": 848
      "range": {
        "from": "2021-12-26T03:05:46.200Z",
        "to": "2021-12-26T09:05:46.200Z",
        "raw": {
          "from": "now-6h",
          "to": "now"
      "from": "1640487946200",
      "to": "1640509546200"
    "hideFromInspector": false
  "response": {
    "results": {
      "Temperature": {
        "frames": [
            "schema": {
              "name": "Temperature",
              "meta": {
                "type": "timeseries-wide",
                "executedQueryString": "SELECT date_parse(\"timestamp-utc\", '%Y-%m-%d %H:%i:%s UTC') AS dt,\r\n\"home-name\", \"wall-name\", \"sensor-name\", \r\nvalue \r\nFROM wall_data \r\nWHERE \"measurement-type\"='temp_c'\r\nORDER BY 1 ASC;"
              "fields": [
                  "name": "dt",
                  "type": "time",
                  "typeInfo": {
                    "frame": "time.Time"
                  "name": "value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float32",
                    "nullable": true
                  "labels": {
                    "home-name": "erez-home",
                    "sensor-name": "air-in",
                    "wall-name": "research-wall"
                  "name": "value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float32",
                    "nullable": true
                  "labels": {
                    "sensor-name": "air-out",
                  "name": "value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float32",
                    "nullable": true
                  "labels": {
                    "sensor-name": "wall-down-deeper",
                  "name": "value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float32",
                    "nullable": true
                  "labels": {
                    "sensor-name": "wall-up-less-deep",
            "data": {
              "values": [
                  1639942092000,
                  1639942107000,
                  1639942201000,
                  1639942802000,
                  1640501941000,
                  1640502001000,
                  1640502602000,
                  1640503201000,
                  1640503802000,
                  1640504401000,
                  1640505002000,
                  1640505602000,
                  1640506202000,
                  1640506801000,
                  1640507401000,
                  1640508002000,
                  1640508601000,
                  1640509202000
                  12.375,
                  12.348,
                  12.332,
                  12.319,
                  12.319,
                  12.292,
                  12.332,
                  0,  // <<<< Should have been NULL
                  8.7,
                  9.039,
                  9.475,
                  9.8,
                  10.051,
                  10.278,
                  10.489,
                  10.727,
                  10.967,
                  11.178,
                  11.347,
                  11.485,
                  11.656
No
I couldn’t find any. Most online resources are about the opposite problem i.e. how to COALESCE - I just want my NULLs to stay NULLs.
I have the same problem :frowning:
