Grafana is throwing false-positive alerts "InstanceDown"
Hi All,
We have this monitoring alert, which is being thrown every 3 hours:
[FIRING:2] InstanceDown (: opsgenie)
Alert: Instance :9113 - web-xyz down
Description: :9113 - web-xyz of job nginx-exporter-stage has been down for more than 1 minutes.
Details:
alertname: InstanceDown
Environment: stage
instance: :9113
instance_id: i-0a2s3d4fg56yhj78k9
instance_name: web-xyz
job: nginx-exporter-stage
prometheus_host: .ec2.internal
severity: opsgenie
Upon checking (querying) in Grafana, result shows it’s down for a long time now.
up{job=“node-exporters”} == 1
  1. The thing is, the instance never went down.
    It’s been up & running all the time, but Grafana (Prometheus) shows differently.
  2. The port 9113 is never really open… (9100 is open, Prometheus uses this, right?)
Grafana v8.0.3 (cae5c5e46b), Ubuntu
figure out the fix for this.
I’m checking if there’s somethings wrong with the prometheus.yml
  • What happened?
Grafana/Prometheus is throwing false alerts frequently.
we expect to only received this alert when the server/s is actually down.
snippet:
  • ec2_sd_configs:
    • filters:
      • name: tag:Role
        values:
        • web-staging-ec2
          port: 9113
          region: us-east-1
    • filters:
      • name: tag:Role
        values:
        • web-prod
          port: 9113
          region: us-west-2
    • filters:
      • name: tag:Role
        values:
        • web-prod
          port: 9113
          region: ca-central-1
    • filters:
      • name: tag:Role
        values:
        • web-prod
          port: 9113
          region: ap-southeast-2
    • filters:
      • name: tag:Role
        values:
        • web-prod
          port: 9113
          region: eu-west-1
          job_name: nginx-exporter-stage
          relabel_configs:
    • action: keep
      regex: .*
      source_labels:
      • __meta_ec2_tag_Name
    • source_labels:
        target_label: instance_name
    • source_labels:
      • __meta_ec2_instance_id
        target_label: instance_id
    • source_labels:
      • __meta_ec2_tag_Environment
        target_label: Environment
No UI errors.
no.
Any tips in troubleshooting/finding a resolution?
796 views and 0 reply. you are really champs
This is a community forum = someone CAN respond. You have still option to pay for the support if you expect that someone MUST respond.
at least a reply that we can go ahead and not wait for nothing. yeah right, with the super champs i pay for nothing
