Grafana / HTTPS / Nginx Proxy
So, I’m starting to feel pretty crazy. I’m unable to access grafana through the https proxy. I’ve looked at the documentation for this a multitude of times. Here is my nginx config:
server {
  server_name my.domain.name;
  listen 443 ssl http2;
  listen [::]:443 ssl http2;
  ssl on;
  ssl_certificate /etc/ssl/certs/cloud_flare_cert.pem;
  ssl_certificate_key /etc/ssl/private/cloud_flare_key.pem;
  index index.html index.htm;
location / {
  proxy_pass http://grafana.staged-by-discourse.com/;
  proxy_set_header Host                 $http_host;
  proxy_set_header X-Real-IP            $remote_addr;
  proxy_set_header X-Forwarded-For      $proxy_add_x_forwarded_for;
  proxy_set_header X-Forwarded-Proto    "https";
With that setup, I have the following in my grafana.ini file.
instance_name = my.domain.name
[server]
protocol = https
# The http port  to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = my.domain.name
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
enforce_domain = true
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://my.domain.name/
# https certs & key file
cert_file = /etc/grafana/cloud_flare_cert.pem
cert_key = /etc/grafana/cloud_flare_key.pem
For the life of me, I cannot figure out what I can’t access grafana by heading to https://my.domain.name.
I do see the following text in my nginx error.log file when I attempt to load the URL:
2019/05/07 05:28:32 [error] 6443#6443: *1 upstream sent no valid HTTP/1.0 header while reading response header from upstream
I’m hoping I’m just tired and missed something silly somewhere. As the cert file names show, I am behind Cloudflare, but I’m not sure what that does in terms of accessibility.
Any assistance here would be greatly appreciated.
You can solve it like this, edit grafana config:
[server]
#here
protocol = http
http_port = 3000
#Here
#cert_file = /etc/grafana/cloud_flare_cert.pem
#cert_key = /etc/grafana/cloud_flare_key.pem
you do not need (I do not believe) https between grafana and the Nginx.
Or maybe you can edit Nginx.conf, But I’m not sure.
location / {
  #here
  proxy_pass https://community.grafana.com/;
I’ll give that a go and let you know what happens. Thanks!
Oh my word. That got me in. Thank you! So, because I’m handling the HTTPS stuff with Nginx, I need not worry about it with grafana? Good to know!
Thanks for the tip. This worked
Grafana, nginx, and letsencrypt - installed on macOS with homebrew.
Hi @danielgonzalez,
I have tried exactly the same but for am still getting the below error.
2021/04/16 11:55:28 [error] 12842#12842: *1 SSL_do_handshake() failed (SSL: error:1408F10B:SSL routines:ssl3_get_record:wrong version number) while SSL handshaking to upstream, client: 80.**.**.**, server: my.proxy.com, request: "GET / HTTP/2.0", upstream: "https://127.0.0.1:3000/", host: "my.proxy.com"
Pasting my config file details below.
/etc/nginx/sites-available/default
server {
server_name my.proxy.com;
ssl on;
ssl_certificate /etc/nginx/ssl-certs/godaddy_cert.crt;
ssl_certificate_key /etc/nginx/ssl-certs/godaddy_key.key;
root /var/www/example.com;
index index.html;
location / {
proxy_set_header X-Forwarded-Proto “https”;
#/etc/grafana/grafana.ini
> instance_name = my.proxy.com
> [server]
> # Protocol (http, https, h2, socket)
> protocol = http
> # The ip address to bind to, empty will bind to all interfaces
> ;http_addr =
> http_port = 3000
> domain = my.proxy.com
> #root_url = %(protocol)s://%(domain)s:%(http_port)s/
> root_url = https://my.proxy.com/
> # Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
> ;serve_from_sub_path = false
> # Log web requests
> ;router_logging = false
> # the path relative working path
> #static_root_path = public
> # enable gzip
> enable_gzip = false
> #cert_file = /etc/nginx/ssl-certs/godaddy_cert.crt
> #cert_key = /etc/nginx/ssl-certs/godaddy_key.key
Could you try this config file?
Thanks, @danielgonzalez for the quick update, but still am getting the same error.
Did you restart the nginx server?
Thanks @danielgonzalez, it is working. I missed to remove s from the proxy_pass http://grafana.staged-by-discourse.com/;
hi, we are trying with this configuration in nginx.conf
  server {
        listen 443 ssl http2 default_server;
        ssl_certificate "/etc/nginx/cert/cert.pem";
        ssl_certificate_key "/etc/nginx/cert/certkey.pem";
        ssl_session_cache shared:SSL:1m;
        ssl_session_timeout  10m;
        ssl_ciphers HIGH:!aNULL:!MD5;
        ssl_prefer_server_ciphers on;
        root /usr/share/nginx/html;
		location / {
		location /grafana/
		    proxy_pass https://localhost:3000/;
			#add_header  Access-Control-Allow-Origin $http_origin;           #this mirrors back whatever domain the request came from as authorized, as
			#add_header  "Access-Control-Allow-Credentials" "true";          #as long as it matches one of your if statements
			#add_header  "Access-Control-Allow-Methods" "GET, OPTIONS";
			#add_header  "Access-Control-Allow-Headers" "Authorization, origin, accept";
			#rewrite  ^/grafana/(.*)  /$1 break;
and this in grafana.ini, but it does not work
[server]
protocol = http
;http_addr =
http_port = 3000
;domain = localhost
root_url = https://10.138.1.117:3000/grafana/
serve_from_sub_path = true
# Log web requests
;static_root_path = public
# enable gzip
;enable_gzip = false
cert_file = /etc/ssl/certs/cert.pem
cert_key  = /etc/ssl/certs/certkey.pem
but the proxy does not work, can you see anything?
if the proxy already ssl terminate, I think you don’t need run grafana in https mode.
So, you can comment the cert in grafana.ini and root_url just the domain of the vhost in the nginx.conf.
Also, the nginx.conf since using https, you need to put server_name according to your ssl certificare name.
First of all, make sure the grafana starting at port 3000 using curl http://localhost:3000,
then you can check the nginx using nginx -t to make sure all the configuration is good.\
After all test woked fine, just restart the nginx,
To make sure all the setup working, you can use curl https://<your_server_name>/grafana
Regards,
Fadjar
@fadjar340 i see this on docker logs
do you know how can i solve?
Hi, you can comment like below:
# root /usr/share/nginx/html;
Regards,
Fadjar
