I am trying to configurate a proxy in nginx.conf for grafana request. My request it will be like:
the request will work with https
https//:ip/grafana/..............
and the request from which is being working is https://ip.com
my nginx.conf is:
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
#gzip on;
include /etc/nginx/conf.d/*.conf;
server {
listen 443 ssl http2 default_server;
ssl_certificate "/etc/nginx/cert/cert.pem";
ssl_certificate_key "/etc/nginx/cert/certkey.pem";
ssl_prefer_server_ciphers on;
root /usr/share/nginx/html;
location /grafana/
proxy_pass https://localhost:3000/;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto "https";
location / {
my grafana.ini is this:
[server]
# Protocol (http, https, h2, socket)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = localhost
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
enforce_domain = true
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://%(domain)s:%(http_port)s/grafana/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
;serve_from_sub_path = true
# Log web requests
;router_logging = false
# the path relative working path
;static_root_path = public
# enable gzip
;enable_gzip = false
i cant find what is wrong because as that the proxy is not working,
as the request works with
https://ip:3000/grafana
but not with
https://ip/grafana
I will be very gratefully if someone help me
best ![]()
