Grafana/SSL/FQDN
Hi, sorry for creating another topic on this subject but i am going a little crazy. I am fairly new to Grafana and can’t start it with ssl. I followed the official documentation on configuring ssl: Docs
I am using Debian GNU/Linux 11 (bullseye) with grafana 9.5.2. And i have my own certificates created for FQDN “my.domain.eu”
I tried configuring it according to documentation and this is what I ended up with:
;instance_name = my.domain.eu
[server]
# Protocol (http, https, h2, socket)
;protocol = https
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port  to use
;http_port = 3000
;domain = my.domain.eu
;enforce_domain = false
;root_url = https://my.domain.eu:3000/
;serve_from_sub_path = false
;router_logging = false
;static_root_path = public
;enable_gzip = false
;cert_file = /etc/grafana/grafana.crt
;cert_key = /etc/grafana/grafana.key
And nothing. Works on http but does not work on https. I always get “Unable to connect”. Using curl gets me “error:1408F10B:SSL routines:ssl3_get_record:wrong version number”. There is no error in grafana.log and the service is running but serving on http.
The certificate permissions are for grafana:grafana and it has 777 permissions (Just for testing).
SO! I tried using nginx reverse proxy and this topic:
Topic
So I installed ngnix and in available sites I added my.domain.eu file with the following configuration:
server {
  server_name my.domain.eu;
  listen 443 ssl http2;
  listen [::]:443 ssl http2;
  ssl on;
  ssl_certificate /etc/nginx/grafana.crt;
  ssl_certificate_key /etc/nginx/grafana.key;
  index index.html index.htm;
location / {
  proxy_pass http://grafana.staged-by-discourse.com/;
  proxy_set_header Host                 $http_host;
  proxy_set_header X-Real-IP            $remote_addr;
  proxy_set_header X-Forwarded-For      $proxy_add_x_forwarded_for;
  proxy_set_header X-Forwarded-Proto    "https";
I copied certificates to /etc/nginx and still nothing. No error in error.log and no access in access.log.
Any help? Thank you in advance
;protocol = https
;http_addr =
;http_port = 3000
the ; ,semi colon, comments out or disables the ini value after it.
