Hi everyone, I’ve been trying to set up Grafana 8.3 to run on my server with SSL using Nginx on Ubuntu 20.04 .3 LTS but I just can’t get it to work. I’ve spent a few hours trying to get this working it’s starting to drive me nuts.
I’ve installed Grafana and it works by default from the servers IP address and domain at sub.example.com:3000 with HTTP. But I want to run it with SSL (Let’s Encrypt).
Can someone share with me grafana.ini and nginx configuration that work with SSL?
Thanks in advance.
welcome to the
forum, @soundium
are you trying to use SSL and still connect on port 3000? I think you will need to set up a proxy pass for that to work. Here is my nginx server block to run Grafana on a subdomain on Ubuntu 20. I got SSL set up using Certbot / lets encrypt
server {
server_name grafana.zuchka.dev;
location / {
proxy_pass http://127.0.0.1:3000;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/grafana.zuchka.dev/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/grafana.zuchka.dev/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = grafana.zuchka.dev) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
