Grafana flux query fail error
As per this issue:
    Grafana v10.0.1 & Ubuntu 22.04.2 LTS
    Resolve errors shown in the grafana-server log file after dashboard refreshes.
    Errors are caused every time a page refreshes (not auto-refresh, but actual F5 style refresh).
  • What happened?
    Server error messages saying:
Jun 23 14:28:46 HOSTNAME grafana[41728]: logger=tsdb.influx_flux t=2023-06-23T14:28:46.584983091+01:00 level=warn msg=“Flux query failed” err=“Post "https://HOSTNAME.HERE:8086/api/v2/query?org=ORG_HERE\”: context canceled" query=“from(bucket: "BUCKET_NAME")\r\n |> range(start: -3s, stop: 2023-06-23T13:28:46.7Z)\r\n |> filter(fn: (r) => r["Metric"] == "Alarm_info")\r\n |> last()”
    No error message.
    N/A.
    The dashboard displays correctly, no errors on the UI.
    None
Hi @olliecampbell
Can you paste your full query here and also a screenshot of it working in Influx Data Explorer?
@grant2 It seems panels with an influx query that ends in ‘last()’ seem to cause this error, but only when the webpage has been left dormant on a tab for a while I think.
If I view a single panel that uses this last() function, and refresh the page, I don’t get an error.
If I open a dashboard with multiple panels, some of which use the last() function, I don’t get an error. I can also refresh this page as many times as I like and there is no error.
If I switch to another tab for a while, as soon as I go back to the dashboard tab, I see this error in the logs.
