Grafana Enterprise source code / Adding annotations as viewer
(not sure in which category to post this question)
Small question: Is the source code for the Grafana Enterprise features publically available (on github)? Or does Grafana Labs keep this offline to protect their incomes?
I am in high need to be able to let viewers create annotations, as quite some others: Annotation role · Issue #9991 · grafana/grafana · GitHub. Since Grafana Labs seems to ignore the demand for such (simple) functionality, I was thinking maybe it is possible to port (a part of ) Grafana Role-based access control (RBAC) | Grafana documentation to the open source version and build it myself, just with the purpose to be able to let viewers create annotations. Within the non-profit research environment I’m developing a tool for that uses grafana, there is simply no budget for an enterprise subscription to only make use of the role-based access control to let viewers add annotations.
@grafana89e9 the source for the licensed features in Grafana Enterprise is private. I don’t know enough about the internals of annotations to tell you if it’s an easy feature to add - how to contribute.
You can read more about how we make decisions about enterprise features here:
Thanks @melori.arellano ! In that case I’m going to look for a way it implement it myself in a couple of weeks!
