Permissions for Annotations
Using Grafana 10.2.2
Presumed Viewers would be able to Annotate trends.
Searched the config file but can’t find any related options.
Only way to get viewers to be able to annotate was to change them to editors which is not ideal.
Our viewers are the customers and they are the ones that are using the dashboards daily, and are the ones that understand the data and trends the best, therefor they are the best source of annotations.
Are there options to allow viewers to annotate?
