Grafana downgrade
    Grafana 9.4.3 installed as standalone binaries on Ubuntu
    Downgrade to 9.3.11
    Replace files from archive with 9.3.11 version
  • What happened?
    Everithing probable works well except edition of alerting policies. When I try to edit notification policies, i got this error Error: failed to save and apply Alertmanager configuration: UNIQUE constraint failed: alert_configuration.org_id
    Everything works well.
I tried to downgrade, because 9.4.X have this bug Notification issue with rocketchat through slack webhook · Issue #65859 · grafana/grafana · GitHub
Is there a way to downgrade without backups?
I dropped UQE_alert_configuration_org_id index in sqlite db with
drop index UQE_alert_configuration_org_id
Now i can edit contact points and policies
