I have the exact same issue: Missing "contact points" and "notyfications policies"
I am opening a new topic to share all the necessary informations.
Yesterday everything was fine. Today both “Contact points” and “Notification policies” are gone. Alert rules and Silences are still there.
I have 4 differents organisations on my grafana and this happened to all of them.
Here is the informations:
What is your Grafana version?
8.4.1, using this docker image: grafana/grafana:8.4.1 -
Are you using Grafana Cloud or self-hosted Grafana?
self-hosted -
Are you using legacy alerting or Unified Alerting?
Unified Alerting -
was the alert in question migrated from the legacy platform into Unified Alerting, or did you first create it inside the new platform?
Alerts, contact points and notifications policies where ccreated inside the new platform -
Please list ALL configuration options related to alerting. You can find these in the
AlertingandUnified Alertingsections of Grafana’s config file. If you are now using or have previously used the beta version ofngalert(released with Grafana 8), please note that too.
unified_alerting:
enable: true
alerting:
enable: false
feature_toggles:
enable: ngalert
One more thing, I found this strange log :
logger=ngalert t=2022-05-09T00:00:18.79+0000 <mark>lvl=eror</mark> msg="failed to save alert state" uid=gsd17ma7k orgId=2 labels="__alert_rule_namespace_uid__=Hcad6lbnz, __alert_rule_uid__=gsd17ma7k, alertname=weather - temperature_outside min, measurement=weather, type=sensor" state=Normal msg="database is locked"
