What Grafana version and what operating system are you using? - v8.3.2 (afb9e8e5f3)
What are you trying to achieve?- One of my query setup in Grafana is not returning more than 100 rows.
What happened?
What did you expect to happen?- The table in DB does have more than 100 records but its not showing in Grafana.
Did you follow any online instructions? If so, what is the URL?- I checked for limit parameter, rows limit parameter but did not find any to resolve this issue. Dont have URL handy now.
I need this issue to be resolved.
What datasource are you using, and what query options are configured?
Dashboard is not configured from backend.
oracle OEM (oracle-emcc-app) datasource,
Looks like this is not a Grafana issue, but you are reaching the limit specified by oracle.sysman.db.restfulapi.grafana.throttle.nontimeseries.maxnumrows property of your datasource.
From EMCC help:
| Property Name |
Data Type |
Default Value |
Purpose |
| oracle.sysman.db.restfulapi.grafana.throttle.nontimeseries.maxnumrows |
number |
100 |
Data Limit Determines the maximum number of rows to return when any query is executed for Grafana Plugin’s Non-timeseries Query Type option. |
Try changing this property by emctl set command and see if it helps:
emctl set property -name oracle.sysman.db.restfulapi.grafana.throttle.nontimeseries.maxnumrows -value 1000
