How can I increase the number of rows to more than 10000 in a table
I am using Grafana v9.2.0 for creating a dashboard in windows.My datasource type is elasticsearch and while creating a table panel in a dashboard it seems like I have limitation of 10000 rows which gives me wrong value at the end when I want to sum up the total cost. It was due to unable to load all data in the table and showing a total to only those that are displayed.
I want to increase my table rows to more than 10000. This is the screenshot for the section where I am changing the total rows displayed.
Hi @pratichhya,
Thanks for opening this post.
You can check this post as it explains a possible workaround on how to increase the limit:
I hope this helps.
