Elastic search limits
Why log metrics showing only 10000 records when datasource as elasticsearch?
Is there anything in configuration that I need to update?
Thank you for your help in advance.
    Grafana v10.0.3 (eb8dd72637)
    need to show all records instead of limitation of 10000
  • What happened?
Because it is a es limit. Try the same query in kibana and you will see es puts that limit not grafana
In Kibana you can leverage the “search_after” API: Paginate search results | Elasticsearch Guide [8.17] | Elastic
