Hello
please should be informed that telegraf how all data of measurements however in grafana does not show all data
can you help please
espechly these lines not displayed
Serial_Number=“3322659325”
,Systemname=“WorkCentre 5330 RDJ1”
What is shown if you hover over the red error icon?
I will check and back to you with an answer
hello here is the error displayed
grafana unsupported mean iterator type: *query.stringInterruptIterator
Try removing the GROUP BY time($__interval) fill(null) and see what happens.
Thanks you very much
systemname is string field and it doesn’t make sense to calculate mean value from the string.
Use some numeric field in mean agg function.
If the above fixed the issue, please mark it as Solution so others can find this in the future.
