I am new to Grafana. I am trying to setup monitoring and dashboard for java based Apache AMQ message broker. I have setup the jmx exporter configuration on the AMQ broker side and exposed the metrics via port 9161.
ACTIVEMQ_OPTS="-javaagent:%ARTEMIS_INSTANCE%\lib\jmx_prometheus_javaagent-0.12.0.jar=9161:%ARTEMIS_INSTANCE%\lib\promconfig.yml"
On Grafana side i configured the datasource using the url as http://localhost:9161 and Access as ‘Server’ mode and HTTP method as GET.
SAVE and TEST -> doesnt give the message “Data Source is working”
When i access the url in browser, i can see the exposed jvm and amq artemis exposed metrics.
When i use the query inspector, it returns the complete metrics page http://localhost:9161 as response instead of the metrics value.
I tried downgrading Grafana version, didnt work.
I enabled debug logging, but nothing is reported as error.
I enabled the below JVM args also, but didnt make any difference.
-Dcom.sun.management.jmxremote
-Dcom.sun.management.jmxremote.authenticate=false
-Dcom.sun.management.jmxremote.ssl=false
Any ideas on how to resolve this? Other datasources like prometheus datasource works fine and i am able to build visualizations from them.
