i’m trying to configure our internal grafana server to read the metrics endpoints for grafana itself (v9.5.8 listening on port 3000) and loki (v2.8.4 listening on 3100).
curl’ing http://localhost:3000/metrics and http://localhost:3100/metrics i see the appropriate metrics for each. in grafana, when i configure a prometheus data source and either of those endpoints, i get a green checkmark with “data source is working”. however, when i explore either datasource and select the metric dropdown, loki flashes a yellow 404 message and the dropdown says “no options found”. the grafana prometheus data source doesn’t flash the 404 message, but still says “no options found”.
is there something else i need to do to get these configurations to work?
thanks!
