Hi
I installed influx on home assistant yesterday v. That worked.
After influx, installed grafana, that did not work.
Virtual machine on Synology nas
Any Idea why this fails:
Add-on: Grafana
The open platform for beautiful analytics and monitoringAdd-on version: 10.0.0
You are running the latest version of this add-on.
System: Home Assistant OS 12.4 (amd64 / qemux86-64)
Home Assistant Core: 2024.6.4
Home Assistant Supervisor: 2024.06.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
Read data from influx and present on grafana on home assistant -
Run grafana on home assistant -
Grafana opened, with no config to influx -
This I dont know how to find it, log under
HA log:
See log -
youtube rXF-LycbjoA&t=60s
LOG:
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-grafana: starting
s6-rc: info: service memcached: starting
s6-rc: info: service memcached successfully started
[11:01:35] INFO: Starting Memcached…
s6-rc: info: service init-nginx successfully started
s6-rc: info: service init-grafana successfully started
s6-rc: info: service grafana: starting
s6-rc: info: service grafana successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
[11:01:36] INFO: Starting Grafana…
s6-rc: info: service legacy-services successfully started
Grafana server is running with elevated privileges. This is not recommended
logger=settings t=2024-06-26T11:01:55.713047729+02:00 level=info msg=“Starting Grafana” version=11.0.0 commit=277ef258d4b9a5acdf2932347c6a4ca72d739b28 branch=HEAD compiled=2024-06-26T11:01:55+02:00
logger=settings t=2024-06-26T11:01:55.769676379+02:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2024-06-26T11:01:55.769734424+02:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2024-06-26T11:01:55.769763421+02:00 level=info msg=Target target=[all]
logger=settings t=2024-06-26T11:01:55.769802444+02:00 level=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2024-06-26T11:01:55.76982639+02:00 level=info msg=“Path Data” path=/data
logger=settings t=2024-06-26T11:01:55.769842477+02:00 level=info msg=“Path Logs” path=/var/logs/grafana
logger=settings t=2024-06-26T11:01:55.769855997+02:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2024-06-26T11:01:55.769869645+02:00 level=info msg=“Path Provisioning” path=/usr/share/grafana/conf/provisioning
logger=settings t=2024-06-26T11:01:55.769883523+02:00 level=info msg=“App mode production”
logger=sqlstore t=2024-06-26T11:01:55.792663974+02:00 level=info msg=“Connecting to DB” dbtype=sqlite3
logger=migrator t=2024-06-26T11:01:56.288312675+02:00 level=info msg=“Locking database”
logger=migrator t=2024-06-26T11:01:56.288452949+02:00 level=info msg=“Starting DB migrations”
logger=migrator t=2024-06-26T11:01:56.549018208+02:00 level=info msg=“migrations completed” performed=0 skipped=558 duration=1.095579ms
logger=migrator t=2024-06-26T11:01:56.550471661+02:00 level=info msg=“Unlocking database”
logger=secrets t=2024-06-26T11:01:56.657194993+02:00 level=info msg=“Envelope encryption state” enabled=true currentprovider=secretKey.v1
logger=plugins.registration t=2024-06-26T11:02:24.209984671+02:00 level=info msg=“Plugin registered” pluginId=grafana-image-renderer
logger=plugin.angulardetectorsprovider.dynamic t=2024-06-26T11:02:31.311403081+02:00 level=info msg=“Restored cache from database” duration=5.469638083s
logger=plugin.store t=2024-06-26T11:02:32.503057712+02:00 level=info msg=“Loading plugins…”
logger=plugins.registration t=2024-06-26T11:02:33.419194065+02:00 level=error msg=“Could not register plugin” pluginId=xychart error=“plugin xychart is already registered”
logger=plugins.initialization t=2024-06-26T11:02:33.419260425+02:00 level=error msg=“Could not initialize plugin” pluginId=xychart error=“plugin xychart is already registered”
logger=plugin.store t=2024-06-26T11:02:33.557363309+02:00 level=info msg=“Plugins loaded” count=54 duration=1.054289256s
logger=query_data t=2024-06-26T11:02:34.770369029+02:00 level=info msg=“Query Service initialization”
logger=live.push_http t=2024-06-26T11:02:35.197905471+02:00 level=info msg=“Live Push Gateway initialization”
logger=ngalert.notifier.alertmanager org=1 t=2024-06-26T11:02:35.566332977+02:00 level=info msg=“Applying new configuration to Alertmanager” configHash=a013a3f424edb13bed8050eaf374d506
logger=ngalert.state.manager t=2024-06-26T11:02:36.830374794+02:00 level=info msg=“Running in alternative execution of Error/NoData mode”
[11:02:37] INFO: Starting NGINX…
logger=infra.usagestats.collector t=2024-06-26T11:02:37.888409887+02:00 level=info msg=“registering usage stat providers” usageStatsProvidersLen=2
logger=provisioning.alerting t=2024-06-26T11:02:38.298081923+02:00 level=info msg=“starting to provision alerting”
logger=provisioning.alerting t=2024-06-26T11:02:38.29814524+02:00 level=info msg=“finished to provision alerting”
logger=ngalert.state.manager t=2024-06-26T11:02:38.436880905+02:00 level=info msg=“Warming state cache for startup”
logger=grafanaStorageLogger t=2024-06-26T11:02:38.453333421+02:00 level=info msg=“Storage starting”
logger=ngalert.state.manager t=2024-06-26T11:02:38.778772488+02:00 level=info msg=“State cache has been initialized” states=0 duration=341.889973ms
logger=ngalert.multiorg.alertmanager t=2024-06-26T11:02:38.80864956+02:00 level=info msg=“Starting MultiOrg Alertmanager”
logger=ngalert.scheduler t=2024-06-26T11:02:39.035745357+02:00 level=info msg=“Starting scheduler” tickInterval=10s maxAttempts=1
logger=provisioning.dashboard t=2024-06-26T11:02:39.112929245+02:00 level=info msg=“starting to provision dashboards”
logger=provisioning.dashboard t=2024-06-26T11:02:39.113364053+02:00 level=info msg=“finished to provision dashboards”
logger=ticker t=2024-06-26T11:02:39.115172471+02:00 level=info msg=starting first_tick=2024-06-26T11:02:40+02:00
logger=secret.migration t=2024-06-26T11:02:39.157770654+02:00 level=error msg=“Server lock for secret migration already exists”
logger=http.server t=2024-06-26T11:02:39.223241321+02:00 level=info msg=“HTTP Server Listen” address=[::]:3000 protocol=http subUrl=/api/hassio_ingress/irVMNtA0sB7P6k2ABIHkaBzbTGX1UZU0TGUdq2q2dhU socket=
logger=grafana-apiserver t=2024-06-26T11:02:45.71519817+02:00 level=info msg=“Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager”
logger=grafana-apiserver t=2024-06-26T11:02:45.748745445+02:00 level=info msg=“Adding GroupVersion featuretoggle.grafana.app v0alpha1 to ResourceManager”
logger=grafana.update.checker t=2024-06-26T11:02:46.489118201+02:00 level=info msg=“Update check succeeded” duration=7.791137788s
logger=plugin.grafana-image-renderer t=2024-06-26T11:03:39.10956482+02:00 level=error msg=“Failed to get browser version” err=map[name:TimeoutError]
logger=plugin.grafana-image-renderer t=2024-06-26T11:03:41.929533972+02:00 level=error msg=“plugin process exited” plugin=/var/lib/grafana/plugins/grafana-image-renderer/plugin_start_linux_amd64 id=564 error=“signal: killed”
logger=server t=2024-06-26T11:03:41.985369528+02:00 level=error msg=“Stopped background service” service=*rendering.RenderingService reason=“timeout while waiting for plugin to start”
logger=tracing t=2024-06-26T11:03:44.603665371+02:00 level=info msg=“Closing tracing”
logger=plugin.grafana-image-renderer t=2024-06-26T11:03:45.483715232+02:00 level=warn msg=“plugin failed to exit gracefully”
logger=ssosettings.service t=2024-06-26T11:03:45.767502214+02:00 level=error msg=“failed to fetch SSO Settings for all providers” err=“context canceled”
logger=ngalert.multiorg.alertmanager t=2024-06-26T11:03:46.54553116+02:00 level=error msg=“Error while synchronizing Alertmanager orgs” error=“context canceled”
logger=ticker t=2024-06-26T11:03:47.140816723+02:00 level=info msg=stopped last_tick=2024-06-26T11:03:30+02:00
logger=grafana-apiserver t=2024-06-26T11:03:48.074590097+02:00 level=info msg=“StorageObjectCountTracker pruner is exiting”
Error: ✗ *rendering.RenderingService run error: timeout while waiting for plugin to start
2024/06/26 11:03:52 [error] 557#557: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-grafana, request: “GET / HTTP/1.1”, upstream: “http://127.0.0.1:3000/”, host: “192.168.0.60:8123”, referrer: “http://192.168.0.60:8123/a0d7b954_grafana”
[11:03:57] INFO: Service Grafana exited with code 1 (by signal 0)
s6-supervise grafana: warning: finish script lifetime reached maximum value - sending it a SIGKILL
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[11:04:00] INFO: Starting Grafana…
[11:04:01] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service grafana: stopping
s6-rc: info: service init-nginx successfully stopped
[11:04:02] INFO: Service Grafana exited with code 256 (by signal 15)
s6-rc: info: service grafana successfully stopped
s6-rc: info: service init-grafana: stopping
s6-rc: info: service memcached: stopping
s6-rc: info: service init-grafana successfully stopped
[11:04:02] INFO: Service memcached exited with code 0 (by signal 0)
s6-rc: info: service memcached successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
