RHEL 8.6
Grafana 9.0.4 -
Dashboard Visualization from InfluxDB for vSphere environment -
Using Dashboard ID 8159 -
What happened?
Showing various Templating Errors -
Work -
*[root@d-ifdb-nm ~]# systemctl status grafana-server.service *
● grafana-server.service - Grafana instance -
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: disabled)*
Active: active (running) since Sun 2022-07-24 09:17:47 IST; 12min ago*
Docs: http://docs.grafana.org* -
Main PID: 1447 (grafana-server)*
Tasks: 13 (limit: 11233)*
Memory: 68.2M*
CGroup: /system.slice/grafana-server.service*
└─1447 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=rpm cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib>*
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=query_data t=2022-07-24T09:17:47.094764699+01:00 level=info msg=“Query Service initialization”
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=live.push_http t=2022-07-24T09:17:47.125947577+01:00 level=info msg=“Live Push Gateway initialization”
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=infra.usagestats.collector t=2022-07-24T09:17:47.420291147+01:00 level=info msg=“registering usage stat providers” usageStatsProvidersLen=2
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=server t=2022-07-24T09:17:47.420554754+01:00 level=info msg=“Writing PID file” path=/var/run/grafana/grafana-server.pid pid=1447
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=grafanaStorageLogger t=2022-07-24T09:17:47.426523476+01:00 level=info msg=“storage starting”
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=report t=2022-07-24T09:17:47.426586397+01:00 level=warn msg="Scheduling and sending of reports disabled, SMTP is not configured and enabled. Confi>
Jul 24 09:17:47 d-ifdb-nm.vlab.lab systemd[1]: Started Grafana instance.
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=ngalert t=2022-07-24T09:17:47.437136817+01:00 level=info msg=“warming cache for startup”
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=http.server t=2022-07-24T09:17:47.445370981+01:00 level=info msg=“HTTP Server Listen” address=[::]:3000 protocol=http subUrl= socket=
Jul 24 09:17:47 d-ifdb-nm.vlab.lab grafana-server[1447]: logger=ngalert.multiorg.alertmanager t=2022-07-24T09:17:47.497453664+01:00 level=info msg=“starting MultiOrg Alertmanager”
*[root@d-ifdb-nm ~]# systemctl status influxd.service *
● influxdb.service - InfluxDB is an open-source, distributed, time series database
- Loaded: loaded (/usr/lib/systemd/system/influxdb.service; enabled; vendor preset: disabled)*
- Active: active (running) since Sun 2022-07-24 09:17:47 IST; 12min ago*
Docs: https://docs.influxdata.com/influxdb/* - Process: 1445 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)*
- Main PID: 1453 (influxd)*
- Tasks: 12 (limit: 11233)*
- Memory: 41.4M*
- CGroup: /system.slice/influxdb.service*
└─1453 /usr/bin/influxd*
Jul 24 09:17:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:17:46.757511Z lvl=info msg=“Starting precreation service” log_id=0bspO9eW000 service=shard-precreation check_interval=10m adva>
Jul 24 09:17:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:17:46.760815Z lvl=info msg=“Starting query controller” log_id=0bspO9eW000 service=storage-reads concurrency_quota=1024 initial>
Jul 24 09:17:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:17:46.763878Z lvl=info msg=“Configuring InfluxQL statement executor (zeros indicate unlimited).” log_id=0bspO9eW000 max_select>
Jul 24 09:17:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:17:46.774358Z lvl=info msg=Listening log_id=0bspO9eW000 service=tcp-listener transport=http addr=:8086 port=8086
Jul 24 09:17:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:17:46.774417Z lvl=info msg=Starting log_id=0bspO9eW000 service=telemetry interval=8h
Jul 24 09:17:47 d-ifdb-nm.vlab.lab systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
Jul 24 09:17:47 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1445]: InfluxDB started
Jul 24 09:27:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:27:46.759687Z lvl=info msg=“Cache snapshot (start)” log_id=0bspO9eW000 service=storage-engine engine=tsm1 op_name=tsm1_cache_s>
Jul 24 09:27:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:27:46.765779Z lvl=info msg=“Snapshot for path written” log_id=0bspO9eW000 service=storage-engine engine=tsm1 op_name=tsm1_cach>
Jul 24 09:27:46 d-ifdb-nm.vlab.lab influxd-systemd-start.sh[1453]: ts=2022-07-24T08:27:46.765847Z lvl=info msg=“Cache snapshot (end)” log_id=0bspO9eW000 service=storage-engine engine=tsm1 op_name=tsm1_cache_sna>
*[root@d-ifdb-nm ~]# systemctl status telegraf.service *
● telegraf.service - The plugin-driven server agent for reporting metrics into InfluxDB
- Loaded: loaded (/usr/lib/systemd/system/telegraf.service; enabled; vendor preset: disabled)*
- Active: failed (Result: exit-code) since Sun 2022-07-24 09:18:55 IST; 11min ago*
Docs: https://github.com/influxdata/telegraf* - Process: 2379 ExecStart=/usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d $TELEGRAF_OPTS (code=exited, status=1/FAILURE)*
- Main PID: 2379 (code=exited, status=1/FAILURE)*
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: telegraf.service: Main process exited, code=exited, status=1/FAILURE
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: telegraf.service: Failed with result ‘exit-code’.
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: telegraf.service: Service RestartSec=100ms expired, scheduling restart.
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: telegraf.service: Scheduled restart job, restart counter is at 6.
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: Stopped The plugin-driven server agent for reporting metrics into InfluxDB.
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: telegraf.service: Start request repeated too quickly.
Jul 24 09:18:55 d-ifdb-nm.vlab.lab systemd[1]: Failed to start The plugin-driven server agent for reporting metrics into InfluxDB.
- Active: failed (Result: exit-code) since Sun 2022-07-24 09:18:55 IST; 24min ago*
Looking for the Perfect Dashboard: InfluxDB, Telegraf and Grafana - Part I (Installing InfluxDB, Telegraf and Grafana on Ubuntu 20.04 LTS) - The Blog of Jorge de la Cruz
Thank You
