I’m trying to create a stack (docker/influxdb_v2/telegraf) to monitor different elements. But I have a problem with Grafana. I activated the 10585 dashboard but in the logs I get:
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:36:37.755406294+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=3 duration=3.164946ms size=1246 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:37:00.950852651+02:00 level=warn msg="Flux query failed" err="invalid: error @1:1-1:5: undefined identifier SHOW\n\nerror @1:6-1:9: undefined identifier TAG\n\nerror @1:10-1:16: undefined identifier VALUES\n\nerror @1:17-1:21: undefined identifier WITH" query="SHOW TAG VALUES WITH KEY = \"host\""
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:37:00.951483956+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=5 duration=5.473401ms size=387 referer="https://tig.xxxx.fr/d/iMowdtHZz/docker-dashboard?orgId=1" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:37:00.954317884+02:00 level=warn msg="Flux query failed" err="invalid: error @1:1-1:5: undefined identifier SHOW\n\nerror @1:6-1:9: undefined identifier TAG\n\nerror @1:10-1:16: undefined identifier VALUES\n\nerror @1:17-1:21: undefined identifier WITH" query="SHOW TAG VALUES WITH KEY = \"docker.group\" "
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:37:00.95478307+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=4 duration=4.418633ms size=397 referer="https://tig.xxxx.fr/d/iMowdtHZz/docker-dashboard?orgId=1" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:39:00.572369348+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=0 remote_addr=192.168.xxx.xxx time_ms=1 duration=1.526988ms size=0 referer= traceID=00000000000000000000000000000000 handler=/api/live/ws
grafana | logger=tsdb.influx_flux t=2022-09-16T12:39:00.810882645+02:00 level=warn msg="Flux query failed" err="invalid: error @1:1-1:5: undefined identifier SHOW\n\nerror @1:6-1:9: undefined identifier TAG\n\nerror @1:10-1:16: undefined identifier VALUES\n\nerror @1:17-1:21: undefined identifier WITH" query="SHOW TAG VALUES WITH KEY = \"docker.group\" "
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:39:00.811452514+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=4 duration=4.728132ms size=397 referer="https://tig.xxxx.fr/d/iMowdtHZz/docker-dashboard?orgId=1" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:39:00.812559408+02:00 level=warn msg="Flux query failed" err="invalid: error @1:1-1:5: undefined identifier SHOW\n\nerror @1:6-1:9: undefined identifier TAG\n\nerror @1:10-1:16: undefined identifier VALUES\n\nerror @1:17-1:21: undefined identifier WITH" query="SHOW TAG VALUES WITH KEY = \"host\""
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:39:00.813022084+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=10 duration=10.258038ms size=387 referer="https://tig.xxxx.fr/d/iMowdtHZz/docker-dashboard?orgId=1" traceID=00000000000000000000000000000000 handler=/api/ds/query
And no graph is displayed.
It’s as if Grafana couldn’t read the contents of the influxdb database even though I have data added by telegraf.
docker-compose.yml
version: '3.5'
services:
influxdb:
image: influxdb:latest
container_name: influxdb
hostname: influxdb
ports:
- "8086:8086"
restart: always
volumes:
- "./influxdb:/var/lib/influxdb2"
- "/etc/timezone:/etc/timezone:ro"
- "/etc/localtime:/etc/localtime:ro"
environment:
DOCKER_INFLUXDB_INIT_MODE: $DOCKER_INFLUXDB_INIT_MODE
DOCKER_INFLUXDB_INIT_USERNAME: $DOCKER_INFLUXDB_INIT_USERNAME
DOCKER_INFLUXDB_INIT_PASSWORD: $DOCKER_INFLUXDB_INIT_PASSWORD
DOCKER_INFLUXDB_INIT_ORG: $DOCKER_INFLUXDB_INIT_ORG
DOCKER_INFLUXDB_INIT_BUCKET: $DOCKER_INFLUXDB_INIT_BUCKET
DOCKER_INFLUXDB_INIT_ADMIN_TOKEN: $DOCKER_INFLUXDB_INIT_ADMIN_TOKEN
DOCKER_INFLUXDB_INIT_RETENTION: $DOCKER_INFLUXDB_INIT_RETENTION
networks:
- backend
- traefik
telegraf:
image: telegraf:latest
container_name: telegraf
hostname: telegraf
depends_on:
- influxdb
restart: always
user: telegraf:998
links:
- influxdb:influxdb
volumes:
- "./telegraf/telegraf.conf:/etc/telegraf/telegraf.conf"
- "/var/run/docker.sock:/var/run/docker.sock"
tty: true
networks:
- backend
- traefik
grafana:
image: grafana/grafana-oss:latest
container_name: grafana
hostname: grafana
restart: always
links:
- influxdb:influxdb
ports:
- 3000:3000
environment:
GF_INSTALL_PLUGINS: $GF_INSTALL_PLUGINS
GF_SECURITY_ADMIN_USER: $GF_SECURITY_ADMIN_USER
GF_SECURITY_ADMIN_PASSWORD: $GF_SECURITY_ADMIN_PASSWORD
volumes:
- "./grafana:/var/lib/grafana"
labels:
- "traefik.enable=true"
- "traefik.http.routers.grafana.rule=Host(`tig.mydomain.xxx`)"
- "traefik.http.routers.grafana.entrypoints=websecure"
- "traefik.http.routers.grafana.tls.certresolver=le"
networks:
- backend
- traefik
networks:
backend:
traefik:
external: true
I tried the dashboard Telegraf - system metrics | Grafana Labs but the same observation, the graphs do not display data.
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.135536181+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:28: string literal key uptime_format must have a value\n\nerror @1:79-1:80: invalid statement: $\n\nerror @1:105-1:114: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"uptime_format\") AS \"value\" FROM \"system\" WHERE \"host\" =~ /$/ AND $timeFilter GROUP BY time($interval)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.13620245+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=5 duration=5.469135ms size=465 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.14338408+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:21: string literal key n_cpus must have a value\n\nerror @1:55-1:77: expected comma in property list, got REGEXEQ\n\nerror @1:62-1:76: string literal key host must have a value\n\nerror @1:69-1:76: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:82-1:83: invalid statement: $\n\nerror @1:108-1:117: unexpected token for property key: ILLEGAL ($)" query="SELECT mean(\"n_cpus\") AS \"mean_n_cpus\" FROM \"system\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null) "
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.143880189+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=5 duration=5.732557ms size=671 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.149313579+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:20: string literal key load5 must have a value\n\nerror @1:36-1:58: expected comma in property list, got REGEXEQ\n\nerror @1:43-1:57: string literal key host must have a value\n\nerror @1:50-1:57: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:63-1:64: invalid statement: $\n\nerror @1:89-1:98: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"load5\") FROM \"system\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.149777437+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=6 duration=6.8832ms size=646 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.151014475+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:27: string literal key used_percent must have a value\n\nerror @1:41-1:80: expected comma in property list, got REGEXEQ\n\nerror @1:48-1:79: string literal key host must have a value\n\nerror @1:55-1:79: invalid expression @1:78-1:79: '\n\nerror @1:55-1:79: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:85-1:86: invalid statement: $\n\nerror @1:111-1:120: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"used_percent\") FROM \"disk\" WHERE (\"host\" =~ /^$/ AND \"path\" = '/') AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.1515033+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=17 duration=17.657756ms size=733 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.174271444+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:25: string literal key usage_idle must have a value\n\nerror @1:49-1:95: expected comma in property list, got REGEXEQ\n\nerror @1:56-1:94: string literal key host must have a value\n\nerror @1:63-1:94: invalid expression @1:93-1:94: '\n\nerror @1:63-1:94: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:100-1:101: invalid statement: $\n\nerror @1:126-1:135: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"usage_idle\") * -1 + 100 FROM \"cpu\" WHERE (\"host\" =~ /^$/ AND \"cpu\" = 'cpu-total') AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.174754102+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=3 duration=3.534512ms size=748 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.18278902+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @2:13-2:27: string literal key usage_iowait must have a value\n\nerror @2:40-2:86: expected comma in property list, got REGEXEQ\n\nerror @2:47-2:85: string literal key host must have a value\n\nerror @2:54-2:85: invalid expression @2:84-2:85: '\n\nerror @2:54-2:85: unexpected token for property key: REGEXEQ (=~)\n\nerror @2:91-2:92: invalid statement: $\n\nerror @2:117-2:126: unexpected token for property key: ILLEGAL ($)" query="\nSELECT mean(\"usage_iowait\") FROM \"cpu\" WHERE (\"host\" =~ /^$/ AND \"cpu\" = 'cpu-total') AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.183253343+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=6 duration=6.636589ms size=741 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.184356913+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:27: string literal key used_percent must have a value\n\nerror @1:40-1:62: expected comma in property list, got REGEXEQ\n\nerror @1:47-1:61: string literal key host must have a value\n\nerror @1:54-1:61: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:67-1:68: invalid statement: $\n\nerror @1:93-1:102: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"used_percent\") FROM \"mem\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.18488327+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=7 duration=7.506453ms size=658 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.187259197+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @2:13-2:20: string literal key total must have a value\n\nerror @2:39-2:61: expected comma in property list, got REGEXEQ\n\nerror @2:46-2:60: string literal key host must have a value\n\nerror @2:53-2:60: unexpected token for property key: REGEXEQ (=~)\n\nerror @2:66-2:67: invalid statement: $\n\nerror @2:92-2:101: unexpected token for property key: ILLEGAL ($)" query="\nSELECT last(\"total\") FROM \"processes\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.187721461+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=7 duration=7.110975ms size=652 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.196249718+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @2:13-2:28: string literal key total_threads must have a value\n\nerror @2:47-2:69: expected comma in property list, got REGEXEQ\n\nerror @2:54-2:68: string literal key host must have a value\n\nerror @2:61-2:68: unexpected token for property key: REGEXEQ (=~)\n\nerror @2:74-2:75: invalid statement: $\n\nerror @2:100-2:109: unexpected token for property key: ILLEGAL ($)" query="\nSELECT last(\"total_threads\") FROM \"processes\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.196709897+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=2 duration=2.580171ms size=669 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.200947374+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:27: string literal key used_percent must have a value\n\nerror @1:41-1:63: expected comma in property list, got REGEXEQ\n\nerror @1:48-1:62: string literal key host must have a value\n\nerror @1:55-1:62: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:68-1:69: invalid statement: $\n\nerror @1:94-1:103: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"used_percent\") FROM \"swap\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.201452203+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=2 duration=2.711409ms size=659 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.220707498+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:13-1:22: string literal key n_users must have a value\n\nerror @1:38-1:60: expected comma in property list, got REGEXEQ\n\nerror @1:45-1:59: string literal key host must have a value\n\nerror @1:52-1:59: unexpected token for property key: REGEXEQ (=~)\n\nerror @1:65-1:66: invalid statement: $\n\nerror @1:91-1:100: unexpected token for property key: ILLEGAL ($)" query="SELECT last(\"n_users\") FROM \"system\" WHERE (\"host\" =~ /^$/) AND $timeFilter GROUP BY time($interval) fill(null)"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.221184152+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=2 duration=2.322431ms size=651 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.241733004+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:28-1:29: invalid statement: ,\n\nerror @1:48-1:49: invalid statement: ,\n\nerror @1:72-1:73: invalid statement: ,\n\nerror @1:92-1:93: invalid statement: ,\n\nerror @1:155-1:156: invalid statement: $\n\nerror @1:181-1:190: unexpected token for property key: ILLEGAL ($)\n\nerror @1:191-1:192: invalid statement: ," query="SELECT mean(total) as total, mean(used) as used, mean(cached) as cached, mean(free) as free, mean(buffered) as buffered FROM \"mem\" WHERE host =~ /$/ AND $timeFilter GROUP BY time($interval), host ORDER BY asc"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.242208692+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=2 duration=2.627242ms size=696 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
grafana | logger=tsdb.influx_flux t=2022-09-16T12:57:40.24949967+02:00 level=warn msg="Flux query failed" err="invalid: compilation failed: error @1:34-1:35: invalid statement: ,\n\nerror @1:66-1:67: invalid statement: ,\n\nerror @1:100-1:101: invalid statement: ,\n\nerror @1:130-1:131: invalid statement: ,\n\nerror @1:158-1:159: invalid statement: ,\n\nerror @1:184-1:185: invalid statement: ,\n\nerror @1:216-1:217: invalid statement: ,\n\nerror @1:246-1:247: invalid statement: ,\n\nerror @1:327-1:328: invalid statement: =\n\nerror @1:329-1:330: invalid statement: '\n\nerror @1:339-1:340: invalid statement: '\n\nerror @1:345-1:346: invalid statement: $\n\nerror @1:371-1:380: unexpected token for property key: ILLEGAL ($)\n\nerror @1:381-1:382: invalid statement: ,\n\nerror @1:383-1:384: invalid statement: *" query="SELECT mean(usage_user) as \"user\", mean(usage_system) as \"system\", mean(usage_softirq) as \"softirq\", mean(usage_steal) as \"steal\", mean(usage_nice) as \"nice\", mean(usage_irq) as \"irq\", mean(usage_iowait) as \"iowait\", mean(usage_guest) as \"guest\", mean(usage_guest_nice) as \"guest_nice\" FROM \"cpu\" WHERE \"host\" =~ /$/ and cpu = 'cpu-total' AND $timeFilter GROUP BY time($interval), *"
grafana | logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=myuser t=2022-09-16T12:57:40.250040999+02:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=400 remote_addr=192.168.xxx.xxx time_ms=2 duration=2.859523ms size=1246 referer="https://tig.xxxx.fr/d/EycMP7nVz/telegraf-system-metrics?orgId=1&refresh=1m" traceID=00000000000000000000000000000000 handler=/api/ds/query
I can’t figure out where the problem is coming from. If you have any idea, thanks in advance.
Philippe.
