Grafana does not startup inside Home Assistent
I am running home assistent on VirtualMachine on a Synology NAS (DS220+). HA runs fine, I could also install InfluxDB and now I would like to use grafana for visualisation.
There my problem starts. I could install grafana HA version 9.2.2 and just today 10.0.0, but as soon as I start the addon the startup is terminated at some point. Unfortunately, I am not able to modifiy the grafana.ini (as suggested in other topics) as within HA this is not “vissible” (not even an ssh connection)
On my Synology I was able to install grafana within a Docker container, but I would rather like to run it as an addon within HA.
This is my Log:
s6-rc: info: service init-nginx successfully started
s6-rc: info: service init-grafana successfully started
s6-rc: info: service grafana: starting
s6-rc: info: service grafana successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
[12:59:41] INFO: Starting Grafana...
s6-rc: info: service legacy-services successfully started
[13:00:51] INFO: Starting NGINX...
2024/05/15 13:01:32 [error] 541#541: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: a0d7b954-grafana, request: "GET /api/health HTTP/1.1", upstream: "http://127.0.0.1:3000/api/health", host: "127.0.0.1:1337"
2024/05/15 13:02:37 [error] 541#541: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: a0d7b954-grafana, request: "GET /api/health HTTP/1.1", upstream: "http://127.0.0.1:3000/api/health", host: "127.0.0.1:1337"
Grafana server is running with elevated privileges. This is not recommended
logger=settings t=2024-05-15T13:02:51.701536945+02:00 level=info msg="Starting Grafana" version=11.0.0 commit=277ef258d4b9a5acdf2932347c6a4ca72d739b28 branch=HEAD compiled=2024-05-15T13:02:51+02:00
logger=settings t=2024-05-15T13:02:51.739435296+02:00 level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2024-05-15T13:02:51.739793972+02:00 level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2024-05-15T13:02:51.740552964+02:00 level=info msg=Target target=[all]
logger=settings t=2024-05-15T13:02:51.740673435+02:00 level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2024-05-15T13:02:51.740688853+02:00 level=info msg="Path Data" path=/data
logger=settings t=2024-05-15T13:02:51.740701816+02:00 level=info msg="Path Logs" path=/var/logs/grafana
logger=settings t=2024-05-15T13:02:51.740714549+02:00 level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2024-05-15T13:02:51.74072787+02:00 level=info msg="Path Provisioning" path=/usr/share/grafana/conf/provisioning
logger=settings t=2024-05-15T13:02:51.740741762+02:00 level=info msg="App mode production"
logger=sqlstore t=2024-05-15T13:02:51.743483301+02:00 level=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2024-05-15T13:02:52.584896949+02:00 level=info msg="Locking database"
logger=migrator t=2024-05-15T13:02:52.584971697+02:00 level=info msg="Starting DB migrations"
logger=migrator t=2024-05-15T13:02:52.797731082+02:00 level=info msg="migrations completed" performed=0 skipped=558 duration=15.862063ms
logger=migrator t=2024-05-15T13:02:52.800400888+02:00 level=info msg="Unlocking database"
logger=secrets t=2024-05-15T13:02:52.876898626+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
2024/05/15 13:03:42 [error] 541#541: *5 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: a0d7b954-grafana, request: "GET /api/health HTTP/1.1", upstream: "http://127.0.0.1:3000/api/health", host: "127.0.0.1:1337"
2024/05/15 13:06:11 [error] 541#541: *7 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: a0d7b954-grafana, request: "GET /api/health HTTP/1.1", upstream: "http://127.0.0.1:3000/api/health", host: "127.0.0.1:1337"
logger=plugins.registration t=2024-05-15T13:06:42.843779338+02:00 level=info msg="Plugin registered" pluginId=grafana-image-renderer
logger=plugin.angulardetectorsprovider.dynamic t=2024-05-15T13:06:44.261542777+02:00 level=info msg="Restored cache from database" duration=976.97444ms
logger=plugin.store t=2024-05-15T13:06:50.139161278+02:00 level=info msg="Loading plugins..."
2024/05/15 13:07:07 [error] 541#541: *9 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: a0d7b954-grafana, request: "GET /api/health HTTP/1.1", upstream: "http://127.0.0.1:3000/api/health", host: "127.0.0.1:1337"
logger=plugins.registration t=2024-05-15T13:07:19.464267673+02:00 level=error msg="Could not register plugin" pluginId=xychart error="plugin xychart is already registered"
logger=plugins.initialization t=2024-05-15T13:07:19.569706061+02:00 level=error msg="Could not initialize plugin" pluginId=xychart error="plugin xychart is already registered"
logger=plugin.store t=2024-05-15T13:07:20.057582362+02:00 level=info msg="Plugins loaded" count=54 duration=29.918427794s
logger=query_data t=2024-05-15T13:07:33.568083701+02:00 level=info msg="Query Service initialization"
logger=live.push_http t=2024-05-15T13:07:38.824969904+02:00 level=info msg="Live Push Gateway initialization"
logger=ngalert.notifier.alertmanager org=1 t=2024-05-15T13:07:44.699292005+02:00 level=info msg="Applying new configuration to Alertmanager" configHash=a013a3f424edb13bed8050eaf374d506
logger=ngalert.state.manager t=2024-05-15T13:07:46.990656587+02:00 level=info msg="Running in alternative execution of Error/NoData mode"
logger=infra.usagestats.collector t=2024-05-15T13:07:48.52963277+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
logger=provisioning.alerting t=2024-05-15T13:07:48.642312486+02:00 level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2024-05-15T13:07:48.642475114+02:00 level=info msg="finished to provision alerting"
logger=grafanaStorageLogger t=2024-05-15T13:07:48.898104986+02:00 level=info msg="Storage starting"
logger=ngalert.state.manager t=2024-05-15T13:07:48.790883625+02:00 level=info msg="Warming state cache for startup"
logger=ngalert.multiorg.alertmanager t=2024-05-15T13:07:48.880773982+02:00 level=info msg="Starting MultiOrg Alertmanager"
logger=ngalert.state.manager t=2024-05-15T13:07:49.761197802+02:00 level=info msg="State cache has been initialized" states=0 duration=970.296572ms
logger=ngalert.scheduler t=2024-05-15T13:07:49.784000143+02:00 level=info msg="Starting scheduler" tickInterval=10s maxAttempts=1
logger=ticker t=2024-05-15T13:07:49.784174229+02:00 level=info msg=starting first_tick=2024-05-15T13:07:50+02:00
logger=provisioning.dashboard t=2024-05-15T13:07:50.928022853+02:00 level=info msg="starting to provision dashboards"
logger=provisioning.dashboard t=2024-05-15T13:07:50.930561461+02:00 level=info msg="finished to provision dashboards"
logger=http.server t=2024-05-15T13:07:55.219954368+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl=/api/hassio_ingress/QkDjsFh4L_5oLjA1KUycNiDK7wnc5dc1DZRh05ef8Ww socket=
logger=grafana.update.checker t=2024-05-15T13:08:30.169806868+02:00 level=error msg="Update check failed" error="failed to get stable version from grafana.com: Get \"https://grafana.com/api/grafana/versions/stable\": dial tcp: lookup grafana.com: i/o timeout (Client.Timeout exceeded while awaiting headers)" duration=40.695546097s
logger=plugin.angulardetectorsprovider.dynamic t=2024-05-15T13:08:29.877038509+02:00 level=error msg="Error while updating detectors" error="fetch: http do: Get \"https://grafana.com/api/plugins/angular_patterns\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
logger=plugin.angulardetectorsprovider.dynamic t=2024-05-15T13:08:30.185364746+02:00 level=info msg="Patterns update finished" duration=38.435327798s
logger=plugin.signature.key_retriever t=2024-05-15T13:08:18.171623179+02:00 level=error msg="Error downloading plugin manifest keys" error="Get \"https://grafana.com/api/plugins/ci/keys\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
logger=plugin.grafana-image-renderer t=2024-05-15T13:09:03.300529886+02:00 level=error msg="plugin process exited" plugin=/var/lib/grafana/plugins/grafana-image-renderer/plugin_start_linux_amd64 id=584 error="signal: killed"
logger=server t=2024-05-15T13:09:03.857946047+02:00 level=error msg="Stopped background service" service=*rendering.RenderingService reason="timeout while waiting for plugin to start"
logger=tracing t=2024-05-15T13:09:04.027751359+02:00 level=info msg="Closing tracing"
logger=ngalert.multiorg.alertmanager t=2024-05-15T13:09:06.724001363+02:00 level=error msg="Error while synchronizing Alertmanager orgs" error="context canceled"
logger=plugin.grafana-image-renderer t=2024-05-15T13:09:07.490688686+02:00 level=warn msg="plugin failed to exit gracefully"
2024/05/15 13:09:14 [error] 541#541: *13 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: a0d7b954-grafana, request: "GET /api/health HTTP/1.1", upstream: "http://127.0.0.1:3000/api/health", host: "127.0.0.1:1337"
logger=ssosettings.service t=2024-05-15T13:09:15.961551993+02:00 level=error msg="failed to fetch SSO Settings for all providers" err="context canceled"
logger=ngalert.scheduler t=2024-05-15T13:09:16.202188483+02:00 level=error msg="Failed to update alert rules" error="failed to get alert rules: failed to fetch alert rules: context canceled"
logger=ticker t=2024-05-15T13:09:16.209180509+02:00 level=info msg=stopped last_tick=2024-05-15T13:08:10+02:00
logger=infra.usagestats.collector t=2024-05-15T13:09:16.811439161+02:00 level=error msg="Failed to get system stats" error="context canceled"
logger=infra.usagestats.collector t=2024-05-15T13:09:16.815755359+02:00 level=error msg="Failed to get system stats" error="context canceled"
logger=grafana-apiserver t=2024-05-15T13:09:29.86521302+02:00 level=info msg="Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2024-05-15T13:09:29.890602641+02:00 level=info msg="Adding GroupVersion featuretoggle.grafana.app v0alpha1 to ResourceManager"
Error: ✗ *rendering.RenderingService run error: timeout while waiting for plugin to start
[13:09:32] INFO: Service Grafana exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[13:09:34] INFO: Starting Grafana...
[13:09:34] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service grafana: stopping
s6-rc: info: service init-nginx successfully stopped
[13:09:34] INFO: Service Grafana exited with code 256 (by signal 15)
s6-rc: info: service grafana successfully stopped
s6-rc: info: service init-grafana: stopping
s6-rc: info: service memcached: stopping
s6-rc: info: service init-grafana successfully stopped
[13:09:35] INFO: Service memcached exited with code 0 (by signal 0)
s6-rc: info: service memcached successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
