How to find grafana.ini file in Docker container?
Hello to all!
I have installed Grafana and InfluxDB on my Synology NAS via Docker. Installed via the GUI of Synology. Everything is working fine.
I now want to add alerting via email in Grafana and to configure that I need to edit the grafana.ini file.
The problem is that I don’t know how to “enter” into the grafana configuration files, as it’s installed as container.
I know how to enter via SSH to my Synology, tried to search the folders, but not much luck.
Can someone help me out?
Regards!
Just run with ssh :
docker ps
→ Get your container $name
Then :
docker exec –it $name /bin/bash
You will get inside your grafana server.
Hope it helps.
Good Luck
Woah! Thank you @wlargou , that worked, had to cd back to the “root” directory for /etc, but figured it out, cheers!
P.S. That was more a Docker related question, rather than Grafana, sorry…
Hi, I have a similar problem. I can’t find an ini file on Grafana configuration. According to your instructions, I will join the Docker, but I can’t get to the CONF directory. There are many folders in the bin directory, but properly on the configuration. Can you help you find an ini file for Grafana
Followed your instructions, but the grafana.ini file is “Read Only” and I am sitting with “bash: sudo: command not found”. Did you have the same issue?
Did you try :
find / -name grafana.ini
Also please check inside /etc that’s where it is supposed to be.
Hope it helps.
Good Luck
Hy nothing
Tnx Where to find grafana.ini on docker installation? - Solutions - openHAB Community
