I’m trying to use templating variables in a “text” panel, using HTML. I have multiple Text Panels split across different rows, each row is repeated per variable.
The variable is $system. However when using the $system syntax in a Text panel I get a list of all of the variables available, not the definition of the singular row in question.
E.G:
$system, might be: { sys1, sys2, sys3 }
Repeated Rows:
sys1
- text panel with $system displays: { sys1, sys2, sys3 }
sys2 - text panel with $system displays: { sys1, sys2, sys3 }
sys3 - text panel with $system displays: { sys1, sys2, sys3 }
What I would like:
sys1
- text panel with $system displays: sys1
sys2 - text panel with $system displays: sys2
sys3 - text panel with $system displays: sys3
Hope this makes sense, basically is there a way of extracting the repeated variable name for use in a panel on the row in question?
