I’d like to grasp how much I can do with templating variables.
I currently have a templating variable $collection of type query, which returns multiple elements. Let’s say that I want to show a series of Singlestat panels for every element in the $collection.
Is this possible? I assume I do a “Repeat Row” on the row containing the series of panels. But how can I access the individual element in each Panel’s Title or Query Expression field? Basically, I want to flatten my information and view it at a glance instead of having to pick the actual element value from the dropdown.
Answering myself: When a Template Variable is specified in the Repeat Row field, accessing the list of values via [[collection]] automatically yields the correct single value for each row.
Hi, I want same functionality and I followed all steps but now when I choose in template “Include all option” or(and) “Multi-value” row divides to quantity of variable values but values becomes N/A. If I remove “Include all option” or(and) “Multi-value” , single value for each instance becomes as it should be (0 or 1). Where is the problem ?
You mean the value of the Panel becomes “N/A”? Usually there is an “!” sign in the top left corner of the panel giving you an error message. Can you paste that error message here?
