Repeating Panel data links - how to get instance value?
I’m using Grafana to demo a project showing statistics for a number of Assets each having a number of Sensors.
So there’s an Assets variable obtained using a query:
select name from monitored_assets where asset_group_id=(select id from asset_groups where site_id=(select id from sites where name='test') and name='Test Pump')
This allows the user to select a view of all four of their sensors on a selected Asset.
Next there’s a Sensors variable obtained using the query:
select metadata->>'identifier' from assets_sensors where asset_id = (select id from monitored_assets where name='$Assets')
The panel is setup to repeat and the query obtains the data using $Sensors and $Assets perfectly. The Panel title works perfectly too giving the name of each sensor using $Sensors.
So the problem is when a data link is added, I want to pull out the, Time, Assets, and current Sensors value so that I can post it to another board to display more specific info about the statistics. But what ever I try I cannot get the Sensor value for the panel I am clicking on, instead I get the whole list, so the Data link URL:
http://localhost/${Assets}/${Sensors}/${__value.time}
Produces:
http://localhost/Asset 1/{Non-driven end bearing,Driven end bearing,Gearbox bearing,Auger bearing}/1573187824000
But… If I use the Panel Links in the General tab with the URL:
http://localhost/${Assets}/${SelectedSensors} the value is resolved properly:
http://localhost/Asset 1/Non-driven end bearing.
I see that this question has been asked two times before: Current value of a repeat variable Getting a single variable from a repeated row without a response.
Grafana Documentation is a little ambigous and scattered …
Because I did not find any Information - except Grafana Documentation - I tried it out and want to share with others …
Following Information are related to Grafana v.8.0.3. Dashboards are built for Prometheus Datasource. (Grafana v5 and v6 are working different but more “intuitive”, v7 I never used)
Assume you have a variable “server” which is derivated with “label_values(host)” and a Dashboard (“All Servers”) with repeating Panels (not “Repeating Rows”, but should work also) which e.g. should show CPU usage for each “server” (Query in Panel: cpu_usage_system{host=~"$server",cpu=“cpu-total”}).
You have a second Dashboard (“Host Details”) which shows detailed information for servers, with variable “host” with same definition like “server” in the first panel. (For clearness I took two different variable names, see later).
Now you want to “drill downfrom first Dashboard (“All Servers”, CPU-Panel) to the second Dashboard (“Host Details”), using the “current instance” of variable “server” as parameter for the Drill Down Dashboard.
Solution:
  1. Copy URL of Dashboard “Host Details” (from Browser)
  2. Dashboard “All Servers”, Panel “CPU”: edit “Panel Link”: Paste copied URL into field “url”:
    (copied URL)?var-host=${server}&${__url_time_range}
Example:
https://grafanaserver.local/grafana/d/4HuhGby7z/host-details?var-host=${server}&${__url_time_range}
var-host=${server}: The important information is: The parameter name “var-host” is concatenated: Prefix “var-” tells Grafana to use the suffix “host” as variable name of the target dashboard, filled with Instance ($server) of the source dashboard.
${__url_time_range}: Grafana Target Dashboard “Host Details” will use the same time range as the Source Dashboard …
I hope I could clear that for all interested people … :upside_down_face:
Regards
Frank
