I’m developing a dashboard to follow a vehicle behaviour. In this sense I have shared crosshairs in the speed, altitude aceleration panels and a geomap route panel for visualization. The sync of the crosshair in the panels and the marker that shows in the route in the geomap is correct, however the mark itself is almost transparent, making it quite hard to see (below).
this is quite different from one of the examples I saw:
In which you can clearly see the marker as the blue dot in the GPS position map.
I need the marker to be more visible, and was also wondering if it is possible to use a custom marker (e.g. my own svg) for the route in geomap.
Thank you all for the attention
