Create (Map) Marker colors based on a color description field in the data
It would be very useful to color markers , especially on maps, directly according to a retrieved field from the data.
The field would be called eg Color and contain color data in the form of the actual color name (Red, Green, Yellow), or RGB or hex
My expected behaviour would be that when field dropdown under the Color menu in the panel, it could derive the marker color directly from there.
I dont mean that we take some field from my data (ie ShipType) and use a mapping in the panel on the right or a random selection from the classic palette.
Am I missing something and there is already something that does that?
I think this maybe pretty similar to :
but this case was closed though even unsolved
Might the following help?
thanks yes the first two options are not what Im looking for.
I just want the marker color to be the same as the color i define in the data. Should be quite straight forward request.
At the moment i am just doing everything nocode/lo-code as I am trying to focus on the business side of things, but if i get a chance I will extend the geomap plugin
