What Grafana version and what operating system are you using? v9.1.2
I have a geomap with points already on the map. Now I want that the colour of each marker to change depending on the string value of a variable. -
I thought the answer was value mappings. So I created a override for variable “fracció” which is the one that I want the colour to change depending on its value:
What happened?
Nothing, the marker colours are still the default colour:
Maybe I have to “disable” this default colour?
That the markers on the map would change depending on the variable value -
None -
None
