Grafana Cloud v8.4.1
- What are you trying to achieve?
Setup a GeoMap panel with shape based on input values. I would like the marker shape / symbol to vary based on an input value
- How are you trying to achieve it?
The symbol tab does not seems to provide this option. The color and size tabs however do provide that option.
Alternatively, it seems we can provide different symbols for different layers. Adding a new layer with only the data that I want to show with a different symbol would work, but it seems the new layers takes the same query as input. I guess I could achieve that by merging both of my queries and having different columns names, such as (lat_q1, lon_q1) and (lat_q2, lon_q2), but this seems unefficient
Have some way to change the marker symbol based on input value from the query
- Did you follow any online instructions? If so, what is the URL?
