Grafana-InfluxDB-Geomap
Hello all,
I think i have some diffuculty in create quaries with influxdb when using Geomap. I have examined all the topic on this task, but i have not been successful. I will try to show the problem i have experienced in detail. I hope this topic will be useful for others
my structure likes ; opcua(simulator) → telegraf → influxdb → grafana
query on influxdb(only for example grafana query is difference) ;
I’m using geohash(string) for location mode
Grafana side ;
i have 2 query for different locations, and each location has 1 specific data
query 1 :
specific data is ST
query 2:
specific date is Temperature
if I do not add join by field transform data it does not work properly;
and if I add this transform data, I cannot select different data queries in different layers (such as query:A,query:B). I added transform data combines my queries ;
and as a result, when I go over location 1, it shows all the data in the query, although I only want to see the specific value belonging to it.
What I want to do is ;
if I go to location 1, only the “ST” value
If I go to location 2, I only want to see the “Temperature” value.
