Hello Community,
Was hoping if someone could help with this request. I am trying to capture count of events from Google Log Based Metrics to Grafana Strat/Gauge
What Grafana version and what operating system are you using? 9.2.1
What are you trying to achieve? Trying to get count of certain events from Google Cloud
How are you trying to achieve it?I am using Google Cloud Monitoring Datasource , created a Log based metric, trying to get count in Gauge\Strat charts
What happened? Count is incorrect, tried checking table, it shows higher count than there is
What did you expect to happen?Accurate Count
Can you copy/paste the configuration(s) that you are having problems with?No
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.No
Did you follow any online instructions? If so, what is the URL?None Provided
