Grafana -> Dynatrace -> GCP
Grafana v9.3.2 installed on RHEL
We have installed the Dynatrace plugin and most metrics are working; however, when we try to pull ANY GCP-related metric from the Dynatrace source it throws an error.
“expected at least 2 matches in [cloud.gcp.bigquery_googleapis_com.query.count.gauge]”
I know this is very speciific, but figured I would post it to see if anyone had insights.
thanks.
-k.
Dynatrace is enterprise plugin → why you don’t contact your Grafana enterprise support with this issue?
I am hitting this same “Expected at least 2 matches” exception when attempting to query DT bizevents metrics with Grafana.
Did you find any resolution?
