Grafana 8.4.3 - Firefox - WIndows 10 -
Pull request counts from the apigee service in Google Cloud Monitoring. -
Using the Google Cloud Monitoring plugin with a service account that has the equivalent of the monitoring.viewer role. I created a query to pull request counts under the MQL editor in a new dashboard:
fetch apigee.googleapis.com/ProxyV2 | metric ‘apigee.googleapis.com/proxyv2/request_count’ | group_by [resource.proxy_name]
I also tried the builder and variable tools to see if I could get the labels to appear somewhere.
- What happened?
I got the data I expected back, BUT all time series’ are labeled as “value_request_count_aggregate” instead of their label. Checking in the network inspector in firefox, it does appear that my client is receiving those label names in the response from Grafana.
The “Builder” for Google Cloud Monitoring consistently returns nothing no matter what fields are selected. The only labels that are shown in the “Group by” drop down are metadata labels (that I believe live at the project level).
Trying to create a variable that queries label values also yielded a similar result: Only metadata labels were shown in the drop down.
I would expect the Grafana client to be able to parse the label names returned in the response from the Grafana server so I can show data that makes sense to our users.
- Can you copy/paste the configuration(s) that you are having problems with?
See query above. I will post images if I can.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
None
- Did you follow any online instructions? If so, what is the URL?
Yes, but I cannot post it as I am a new user apparently.
