Metadata.user_labels.appname (not present in gcp plugin)
I was unable to find metadata.user_labels.appname in the filter. Please let me know if it is not supported. Thanks
Hi @vadiksdba
Welcome to the Grafana Forum :+1:
Regarding metadata values, have you seen this note in the Cloud Monitoring Plugin code about getting them to work?:
That’s perfect!!.. Thanks
Hi. I’m unable to see any user_labels in grafana panel. Not even in the Group By dropdown. I want to filter using a user_label.
Is there something else I need to enable or is it not supported? Using grafana cloud
