From CSV, How to filter multiple values using Infinity Data source
  1. i have a CSV file having below data
PTNO,TEST1,Status,Resource,Description
1,Test1-1,Closed,Raj,Test3-1
2,Test1-2,Open,Ravi,Test3-2
3,Test1-3,In-Progress,Linga,Test3-3
4,Test1-4,Open,Chitra,Test3-4
5,Test1-5,Closed,Ajay,Test3-5
6,Test1-6,Open,Raj,Test3-6
7,Test1-7,Closed,Ravi,Test3-7
8,Test1-8,In-Progress,Ajay,Test3-8
#2. I have created a Variable as Status filter - Multiple check box
#3. When we select 1 status say Closed, i could see the table data reflecting with closed status
#4. When we select Closed & Open when we dont see data reflecting on the table.
Welcome @rajasekhar1480
Which plugin are you using
Hi Yoiasz - i m using "yesoreyeram-infinity-datasource " add-in
What does your filter look like
See if this helps Filtering data | Grafana Enterprise plugins documentation
Hi Yosiasz - uploaded the snapshot… kindly take a look and advise
Thanks Yesoreyeram for sharing the link… ll review and see if i can resolve
Thanks a lot @joachimschiewek for providing the solution… But i see 1 problem now.
The filter works fine when we set multiple options where as fails when we set with single option instead of Multiple option.
for multiple selection - pls refer attached working_status.png file - working fine as expected
with single selection - pls refer attached failed_status.png file
Could you pls assist the fix for single selection aswell
please try the UQL Parser…
Jo
Works like a charm using UQL … Thanks @joachimschiewek for your time in resolving the issue… Appreciate it !!
Sorry you were having issues but glad you find the workaround.
I am able to reproduce this by meself. Seems there is an issue with the underlying library. I created a github issue to track this.
It works well when i use inline source
but when i switch to url source i got this error :
Bests regards
Click or hover on fhat warning :warning: icon and see what it says
i was able to fix the issue and now i have a dashboard with chained variable setup.
Sorry for the inconvenience
Hi joachimschiewek,
I did the same thing and I got “error applying uql query”
