Grafana v11.0.0 -
I would like to select multiple values from list and display all of them with trend visualization -
Data source: infinity (plugin)
Type: JSON
Parser: UQL
Source: Inline
format: data Frame
I added a variable names Rank from the JSON (i.e 0,1,2)
I also used Transform data to change the format of “time” and “hight” to number
What happened?
I can only view one selection at a time -
be able to select multiple selection from list -
UQL query:
parse-json
jsonata “People[Name = ‘Alex’ and number = 1 and rank in $Rank][ ].data[ ]” -
I tried following this link:
Simple JSON API & Dashboard Variables don't appear to work - #13 by yosiasz
