Hi!
I’m new in Grafana and I have a problem with variables and time picker using Infinity plugin.
What Grafana version and what operating system are you using? Grafana v10.1.1; Ubuntu Server 22.04.2 LTS
I’m using Infinity plugin to extract data from Google Sheets, everything is working but I can’t use the time picker (I think that is an URL problem) and a I can’t filter by two or more variables, when using one everything is ok. -
How are you trying to achieve it? I set the variables and then I try using them in the filter box that is located in the menu of the backend parser, when I use one of the variables everything works great, but I can’t use two of them at the same time in the same panel. I mean, I can filter by name but I can’t filter by name+year which are two different columns in the CSV.
What did you expect to happen? I want the results to be filter by two or more variables but nothing happened
With this everything is working well but I don´t know how to add the other condition.
I also need help with the time picker, if someone knows what do I need to add to the link to use it please tell me
Thank you!!
