I want to use data from my CSV file as data source in Grafana 10
I know how to use variables to filter data from MySQL query but I don’t know where to filter CSV data with variables. There is no explicit place to put in variables like in MySQL query.
Hello, I would like to know if you managed to solve this problem? I’m trying to make dynamic panels in Grafana from CSV files but I can’t link variables to the panel.
It is not clear what you are trying to do? What are make dynamic panels and what do you mean by but I can’t link variables to the panel.
Below documentation can be used to achive multi input
I have used ‘${servers:csv}’ to achive manual multi inputs where I am passing multiple inputs on the fly, this is useful when one can not add these values in a predefined dropdown values
Hello Manu, can you give a step to add variable to csv data pulled from API.
are you using infinity plugin?
Yes using Infinity plugin
check out uql with parse-csv and filter documentatiom, try it out and post when stuck
https://grafana.github.io/grafana-infinity-datasource/docs/uql
this wont work for grafana visualization
